I've searched the forums for almost 30 minutes and can't find any posts related to this. If it's in here somewhere, can someone post a link?
I have the seat off but I don't know if it's okay to unplug the wires,etc. I can't find the manual that came with the bike so, before I electrocute myself, I thought I should reach out to the experts. Thanks for your help...as always.
Only a biker knows why a dog sticks his head out of a car window☺ ![]() 2006 Aero Candy Orange/Black |
Just make sure you disconnect the NEGATIVE cable first. Than the Pos.
That's the safest way to remove the battery
![]() Ride fast and take chances... uhh, I mean... ride safe. Patriot Guard Riders |
#3 (permalink) |
But there's a big plug on top of the battery containing a bunch of wires. It looks like it's attached to some sort of plastic plate that looks like it slips into a slot on the battery itself. Do I unplug it? Slide it out?
#4 (permalink) | |
#6 (permalink) | ||
Electricity flows from the "+" to the "-" so if you disconnect the "-" it has nowhere to go, therefore there will be no spitzensparks or poppenzefuzens.
'98 Shadow 1100 ACE
#7 (permalink) | |
My guess by looking at the picture is that you remove that single screw at the top. Then the black plate under the connector.......with connector still attached.....slides back a tiny bit and the lifts up and out of the way......well mostly out of the way. THEN you should be able to see the battery posts ......where you will disconnect the black, negative, ground one first.....and secure it out of the way before working on the red, positive, HOT post. If you don't hit both posts at the same time with a metal tool, the odds of making sparks is about nil. P.S. Be sure the new battery is fully charged BEFORE you install it in the bike. If it came with instructions, you probably should READ them !! |
#8 (permalink) | |||
#9 (permalink) | ||
Also, how do I secure the black connector? It can't touch metal, so how do I keep it out of the way and still keep it away from the frame? I really want to do this myself. I do a lot of things myself, but electrical always scared me.
#10 (permalink) | |||
'98 Shadow 1100 ACE
