carb setting - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 3 (permalink) Old 02-24-2010, 07:23 PM Thread Starter
carb setting
does anyone know how many turns to set air mixture screws on a stock 1983 vt500?
417max is offline
post #2 of 3 (permalink) Old 02-24-2010, 09:44 PM
tubes_rock's Avatar
These bikes came pretty lean from the factory. Using the "idle drop procedure" in the official manual, your idle mix screws will likely be set between 2 and 2.5 turns. This is too lean to generally get nice throttle response and you may end up with some popping during deceleration.
Many folks (including me) just set them at 3.25 turns and call it done. Gives better throttle response off the line and eliminates deceleration popping.
--Justin
Currently Running Stable:
2010 Honda NT700V
1986 Shadow 700
1987 Honda Rebel 450
1973 Honda Mini Trail 50
tubes_rock is offline
post #3 of 3 (permalink) Old 02-25-2010, 08:49 PM Thread Starter
thanks
im going to clean the carbs and I will set the screws at 2.5 and go from there thanks for the help
417max is offline
