1986 Shadow 1100 Oil Capacity - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 8 (permalink) Old 03-22-2010, 12:10 PM Thread Starter
OK...I have looked high and low and cannot find the answer to this...what is the engine oil capacity for a 1986 Honda Shadow VT1100? I did an oil change on it this weekend...put in 2 1/2 quarts, started and ran for two minutes than checked levels (Stick came out dry), repeated for 3 and 3 1/2 quarts...both times dry...out in the rest of the fourth and stick came out looking to full. Each time I added oil, ran for 2 minutes, shut off, cleaned stick, dipped and checked level.
Any help is appreciated...
C
1986Shadow is offline
post #2 of 8 (permalink) Old 03-22-2010, 12:54 PM
Seems that you already know the answer of about 4 quarts. Unless you suspect that someone switched out the dip stick on you or your checking it while on the side stand?
I believe all the shadows are in that 3-4 quart range.
Maybe someone who has the same bike can give you the exact amount but I'd say you don't have a problem.
Three things that are not long hidden; the sun, the moon and the truth.
2005 Aero
1972 Honda XL250 Motorsport
2006 Rebel - daughter (Now gone)
1974 XL100
thunderglass is offline
post #3 of 8 (permalink) Old 03-22-2010, 12:54 PM
From the Clymer Manual:
1985-1986
Oil and Filter change 3.3 liter (3.5 U.S. qt.)
At Overhaul 3.8 liter (4.0 U.S. qt.)
1985 Honda Shadow 1100VT
Isaiah 40:28-31
Strength in the Lord.
JFrost is offline
post #4 of 8 (permalink) Old 03-22-2010, 01:38 PM
my 96 ace 1100 , 3.5 without filter , 3.7 with filter , 4.1 on overhaul,
plus i change mine this year after sitting all winter it will take 4.0 on the money
blonoacedmc is offline
post #5 of 8 (permalink) Old 03-22-2010, 02:14 PM Thread Starter
Thank you everyone...sounds like I went through it correctly.
post #6 of 8 (permalink) Old 03-22-2010, 02:19 PM
Iím thinkiní that 3.5 quarts puts my 85 VT1100 just a little above the full mark after the bike has been sitting all night on the center stand.
If you are running the motor only two minutes and not warming up the oil, the oil may need more time to run back down to the sump before checking.
callmeal is offline
post #7 of 8 (permalink) Old 03-22-2010, 02:30 PM Thread Starter
I have the Haynes manual and that is how they state you should check the oil level after doing a an oil / filter change. Funny thing about the manual, it does not state engine oil capacity.
post #8 of 8 (permalink) Old 03-23-2010, 12:44 AM
I had a chance to ride today, so I checked the oil both ways. Checked it first the way I normally do and the oil level was a little under the full mark.
Then started it for a few minutes, warmed it just enough it would idle without the choke, shut it off and let it sit about four minutes. The level was a little above the add mark. So, the difference was about Ĺ of the operating range on the dipstick.
The owners manual says to check the oil the same way as the Haynes.
The 670cc Honda V-twin on my mower also uses the same procedure for checking the oil.
callmeal is offline
