coolant water - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 14 (permalink) Old 04-11-2010, 02:51 PM Thread Starter
coolant water
can I put regular car coolant in my shadow is the same liquid right?
Asielvlx is offline
post #2 of 14 (permalink) Old 04-11-2010, 03:09 PM
MidnightToker's Avatar
yes.
2003 Harley Davidson 1200C Sportster (crashed)
2003 Honda Shadow Sabre 1100
MidnightToker is offline
post #3 of 14 (permalink) Old 04-11-2010, 03:39 PM
Send a message via AIM to Merlin02 Send a message via MSN to Merlin02 Send a message via Yahoo to Merlin02
Re: coolant water
You need to use a Type 2 silicate free coolant designed for use in aluminum engines. Type 1 auto coolant is silicate-based and designed to work with cast iron engine blocks.
Merlin02 is offline
post #4 of 14 (permalink) Old 04-11-2010, 03:45 PM
I used automobile antifreeze in my '97 1100 Spirit and something in it ate up the waterpump seal. I had a leakage there.
I replaced the seal.
I had to take the engine completely loose from the frame. I to then turn the engine sideways to get at the waterpump.
Big Job!
Now I use the Honda coolant.
Jack
Jack772 is offline
post #5 of 14 (permalink) Old 04-11-2010, 04:57 PM
Re: coolant water
BS.
The LARGE majority of engine parts like water pump and etc on cars now a days are aluminum.
And Prestone fills these needs.
You dont need anything special.
post #6 of 14 (permalink) Old 04-11-2010, 05:10 PM
Re: coolant water
BS.
You need 100% silicate free anti-freeze - which is getting much easier to find - but feel free to put silicated antifreeze in your ride. Just beware the first step to changing a water pump on a VT1100 is 'Remove Engine".
Cbjr is offline
post #7 of 14 (permalink) Old 04-11-2010, 05:13 PM
Re: coolant water
BS.
No BS. Silicate free or save up to replace engine parts.
simpleman77 is offline
post #8 of 14 (permalink) Old 04-11-2010, 05:35 PM
AZ Rider's Avatar
Wow, I wonder how many people (riders) actually know this? I sure didn't. I used the pre-mixed stuff off the shelf at auto zone to fill my overflow tank prior to getting it replaced. I thought I had looked in my manual first, but I was looking to see what the mix percent was and not the type.
AZ Rider is offline
post #9 of 14 (permalink) Old 04-11-2010, 06:07 PM
I agree it needs to be silicant free, I should have been much clearer in my edit.
What I ment is that is does not have to be Honda fluid.
post #10 of 14 (permalink) Old 04-11-2010, 06:25 PM Thread Starter
thx for the info
I have a gallon of Prestone that i use for my car and it says its silicate free and protect aluminum engine so that should be ok thx again u guys are so helpfull
Asielvlx is offline
