Headlight modulator review - Honda Shadow Forums : Shadow Motorcycle Forum
Old 04-13-2010, 10:00 PM   #1 (permalink)
Send a message via AIM to jeepinny
Default Headlight modulator review
I just installed the headlight modulator that JC Whitney sells made by Amperite and I am extremely happy with it. http://www.jcwhitney.com/headlight-d.../p2010075.jcwx
First of all it is a fraction of the cost of some of the others that I have seen.
Second it works real well. http://s8.photobucket.com/albums/a30...00413-1846.flv
Although it's a little tough to see in the video it flashes real nice.
Only downfall is it has no optical eye to turn it off at night, but what I did is hooked it up in line with the highbeams. I usually only use low beam at night anyway, so it will only be on with my highbeams.
Time will tell on how durable it is but so far I like it and recommend it to anyone looking to buy one.
I also bought their brake light pulsator...when you hit the brakes it pulses 5 times then stays solid.[/url]
1985 VT1100
Patriot Guard Rider
jeepinny is offline   Reply With Quote
Old 04-14-2010, 12:10 AM   #2 (permalink)
Thanks, very helpful post.
The outside of a motorcycle is good for the inside of a man.
johns750ace is offline   Reply With Quote
Old 04-14-2010, 08:15 AM   #3 (permalink)
adlowe's Avatar
Ya know, I have a hard time buying that those guys actually know what they're talking about. Consider:
it flashes the headlamp every 1/10th of a second
and
The rate of modulation is 200 to 280 cycles per minute
Now I'm not claiming to be a math wizard but it isn't too hard to figure that there are a total of 600 tenths of a second in each minute -- meaning there should be 300 cycles. Where did the other 20 to 100 go?
Art's 1999 Shadow 1100 ACE
adlowe is offline   Reply With Quote
Old 04-14-2010, 08:48 AM   #4 (permalink)
and
Dude, it's JC Whitney!
simpleman77 is offline   Reply With Quote
Old 04-14-2010, 10:51 AM   #5 (permalink)
and
+1,000
It looks to flash less then what they say (looks to be 2 flashes/1 sec judging by my eyeball) but who cares it works perfectly. It's not like they are using their awesome description to justify a large price considering they are priced inexpensive compared to others on the market.
You really don't have to be a math wizard to throw together some very simple circuits. Hell I got electric out of a potato when I was in elementary school, doesn't mean I knew the mathematic equations of what was happening though
1985 VT1100
Patriot Guard Rider
Old 04-14-2010, 12:02 PM   #6 (permalink)
still_bluenoser's Avatar
no high beam eh.... Not a fan of that. I sure would like to have a modulator though!
1983 vt500c
1979 cbx
still_bluenoser is offline   Reply With Quote
Old 04-14-2010, 01:15 PM   #7 (permalink)
You could wire it through a switch if you really wanted to
1985 VT1100
Patriot Guard Rider
Old 04-14-2010, 01:43 PM   #8 (permalink)
Default Modulator
Wonder how much it will cost after you get a ticket for not turning it off at night?
jpr1968 is offline   Reply With Quote
Old 04-14-2010, 02:02 PM   #9 (permalink)
I know. Thats likely what you should do too.
1983 vt500c
1979 cbx
Old 04-14-2010, 02:41 PM   #10 (permalink)
O'Larry's Avatar
Send a message via MSN to O'Larry Send a message via Yahoo to O'Larry
A simple on/off switch in the hotwire should suffice very well.
O'Larry
Ride Bell by Kara-MIA BELL by Bear
'04' Black Flame Sabre
O'Larry is offline   Reply With Quote
