Changing rear tire - Honda Shadow Forums : Shadow Motorcycle Forum
Old 04-16-2010, 05:45 AM   #1 (permalink)
Default Changing rear tire
How much trouble is it to change the back tire on 06 spirit. shop wants 150.00 to take it off the bike and change it. Any thing special about taking off the wheel? If its not to much hassle I would take it off my self is there realignment issues? What about the shaft drive? Sorry for all the questions. Tire should be here today would like to ride by saturday. Any help would be appreciated. Thanks Crash Murdock
Don't kill it if you won't eat it!!!
Crash Murdock is offline   Reply With Quote
Old 04-16-2010, 06:42 AM   #2 (permalink)
get a shop manual. I do believe u need the rear tire off the floor at least 36", or take the rear fender off. read the book.
"smile"... That's the second best thing you can do with your lips!!!
95ace110055 is offline   Reply With Quote
Old 04-16-2010, 07:07 AM   #3 (permalink)
Jack up the bike, it only needs to have the rear tire about 8-10" off the ground. Remove axle, disconnect rear brake, slide whole tire to the right to release the rim from the gear splines. Clean splines and lube with moly paste (very important). and reverse process to put back on. Once the bike is up in the air, it takes about 10 minutes.
Shaft drives really don't have alignment issues. The hard part is getting the bike in the air. The 1100 motor hangs below the frame, so you either have to have a jack with adapters to grab the frame, or use a car jack to just get the rear wheel off the ground.
If you're at all handy, I'd invest in the motorcycle jack and adapter. You can make your own adapters out of wood, or just buy http://garage-toys.com/unmoad.html
2004 Shadow Spirit 1100
http://www.ama-cycle.org/
docc30 is offline   Reply With Quote
Old 04-16-2010, 10:51 AM   #4 (permalink)
If you have a place to work on it.
If you have a means to get the bike up in the air.
If you have a few tools.
If you have a bead breaker.
If you have an air source.
If you have some tire tools.
If you have some dyna beads.
It's not very hard if you have these things.
Three things that are not long hidden; the sun, the moon and the truth.
2005 Aero
1972 Honda XL250 Motorsport
2006 Rebel - daughter (Now gone)
1974 XL100
thunderglass is offline   Reply With Quote
Old 04-17-2010, 10:31 AM   #5 (permalink)
Thanks for all the help I got it off with no problems wasn't as bad as I thought it was gonna be. Now I'm gonna go riding BYE BYE!!!!!!!!!!!!!!!
Old 04-17-2010, 10:38 AM   #6 (permalink)
MidnightToker's Avatar
lol
2003 Harley Davidson 1200C Sportster (crashed)
2003 Honda Shadow Sabre 1100
MidnightToker is offline   Reply With Quote
Old 04-17-2010, 09:20 PM   #7 (permalink)
I have changed about 7 or 8 tires on 4 different bikes.... some are a little more challenging than others.... low profile tires are a pain! I have a two car garage to work in, a large variety of tools, small air compressor, bike jack, and I bought the Harbor Freight tire changing apparatus. It's not a difficult job, an extra set of hands was helpful also.
Pastor Ron A
Patriot Guard Riders #58,820
Senior Ride Captain District #9
Christian Motorcyclists Association
Riding powered 2 wheels since 1969
2002 Honda Shadow Spirit 750
Pastor Ron A is offline   Reply With Quote
Old 04-17-2010, 09:25 PM   #8 (permalink)
Default Re: Changing rear tire
Check your shop's hourly rate; they must be charging $300.00 per hour.
'98 Shadow 1100 ACE
Notorious is offline   Reply With Quote
Old 06-18-2010, 03:06 PM   #9 (permalink)
adlowe's Avatar
THREE FEET? Really?? That's more than 10" higher than the tire is tall!
I think I'll try the 8 to 10 inches that doc330 recommends first.
Art's 1999 Shadow 1100 ACE
adlowe is offline   Reply With Quote
