#11 (permalink) | |
2001 ACE Deluxe
#12 (permalink) | |||
#13 (permalink) | ||
I don't have enough guts to put down my stand in a RH turn to see if the engine will die without pulling the clutch in Any test pilots out there BTW I liked the rubber end on the kickstand of older model bikes a lot better than the electronic version on the newer ones. The rubber end ones left no doubt in ones mind that you forgot to put up your stand
#14 (permalink) | |
#15 (permalink) |
The motor will deff cut off when in gear and you put the side stand down. Clutch position can be either in or out, if it's in gear the motor stops.
This is to prevent you from starting it in gear and having it lurch foward into something or one. This is how I turn mine off almost every time I park somewhere. Much easier than putting it in netural and reaching down for the key then putting back in gear to keep it from rolling off.
1996 VT1100C2 ACE |
#16 (permalink) |
After having watch a couple of bikes roll off their sidestands and go CRUNCH (Not mine thankfully), I have made it a habit to shut the engine off with the sidestand! Works for me!
O'Larry Ride Bell by Kara-MIA BELL by Bear '04' Black Flame Sabre
