to replace or not to replace? - Honda Shadow Forums : Shadow Motorcycle Forum
Old 04-19-2010, 11:07 PM   #1 (permalink)
Default to replace or not to replace?
If you dont like to read you can just skip to the last paragraph
Since this is my first post Ill give a little background to myself and how I came to purchase a beat up 1983 honda shadow vt750c. for the past few years iv had the itch to learn about things mechanical. I also had the itch to ride a motorcycle. added to that there is my current part time employment and... well.... a slightly aged shadow I have purchased for $250. which with all things considered I think was a pretty good deal. Especially since the carbs were cleaned right before i bought it maybe tomorrow Ill make a longer post with pictures and all that fun stuff. but for now I have a quick question.... well not so quick as it should have been hah.
Im rebuilding the calipers right now... well I will once my seals come in. Do you guys think i should also replace the brake lines? In my inexperienced eye they look to be in pretty decent shape.
Thanks!
Cetch is offline   Reply With Quote
Old 04-19-2010, 11:13 PM   #2 (permalink)
carscomefirst's Avatar
in my opinion
When it comes to brakes, new never hurts anything.So, when in doubt, replace it.
But then again im also a member of the when all else fails, force it. If it breaks, then it needed replacing anyways.
07 vlx 600(hers)
98 ace 750(his)
carscomefirst is offline   Reply With Quote
Old 04-19-2010, 11:22 PM   #3 (permalink)
Brake lines are the most overlooked areas on most bikes. Since they look fine on the outside, it's good, right?
These lines weaken and break down over time, allowing them to stretch with brake pressure. While it's not an outright failure of the brakes, it does take away from their effectiveness, and "flaps" that break down from the liner can cause very hard to diagnose problems, even brake lockup.
One thing I recommend, and have done this many times in the past, is to order a "universal" aftermarket braided stainless steel line. Earls is the company most use, there are others. Basically, you measure your stock line (or what you'll need if switching to higher or lower handlebars) from the end of one crimp fitting to the other. Then you order the closest length line, which will come with female threaded ends. You also order the new chrome or stainless fittings that are the closest match to the ends of the stock lines. Add some crush washers (may be included, but check) and you're the proud owner of a superior brake line that many times costs less than ordering a stock OEM from the dealership. They don't flex, they're Teflon lined normally, and they just look good.
Be sure to inspect your caliper pistons and replace if they're pitted. And when you can't figure out why you can't bleed the brakes, crack open the banjo fitting that bolts to the master cylinder, large air bubbles love to hand out there. Even Mityvacs don't work if you don't eliminate that bubble.
Welcome to the wonderful world of Shadows. They're loyal beasts, as long as you treat 'em right.
txironhead is offline   Reply With Quote
Old 04-20-2010, 06:18 AM   #4 (permalink)
Replace 'em. Avoid future problems.
Welcome to the board. No pic's, never happened. Keep us up with progress posts also. Glad to have you here. Lots of knowledgeable people and good info. Good luck.
Eric
simpleman77 is offline   Reply With Quote
Old 04-20-2010, 06:01 PM   #5 (permalink)
Just the kind of direction I was looking for, thanks for the info. Are there any forum sponsored / affiliated bike supply websites that I should order the lines from? if not any recommendations on where to order from.
Thanks
Old 04-20-2010, 11:35 PM   #6 (permalink)
Dennis Kirk used to have decent prices on the brake lines, but there are many other suppliers people here like.
Old 04-21-2010, 03:58 AM   #7 (permalink)
MidnightToker's Avatar
Originally Posted by carscomefirst
in my opinion
I FULLY agree with this.
Sure it will cost money, but you will have a completely new system and it will GREATLY reduse the rust in the lines.
2003 Harley Davidson 1200C Sportster (crashed)
2003 Honda Shadow Sabre 1100
MidnightToker is offline   Reply With Quote
