Valve Clearance check - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 3 (permalink) Old 06-05-2010, 12:22 PM Thread Starter
Thought it best to get my valve clearance checked to make sure its within specs. How long should a shop take to do this hour wise?
Its for an 1984 VT500C
Thanks
Crash
1984 VT500C Shadow Ox Blood Red
CrashOverride is offline
post #2 of 3 (permalink) Old 06-05-2010, 10:44 PM
tubes_rock's Avatar
Just checking, since I'm not familiar with this year, but many Hondas in your early-1980s era had hydraulic lifters and don't require any adjustment at all.
Be sure yours can be adjusted before you bring it anywhere!
--Justin
Currently Running Stable:
2010 Honda NT700V
1986 Shadow 700
1987 Honda Rebel 450
1973 Honda Mini Trail 50
tubes_rock is offline
post #3 of 3 (permalink) Old 06-05-2010, 10:49 PM
Nope, the 500 has solid lifters and needs adjustment.
It's a bit of a PITA, but I did mine with a feeler gauge and hand tools in under an hour, but I already had the tank and snorkel off. The special Honda tools aren't needed, and I'm not sure they'll even fit in there. The access plate in the front against the radiator and the one in the rear next to the airbox are the hardest, as you can barely get in there.
If a competent shop charges you more than 2 hours labor, they're screwing you. I did mine under one hour, and I'd never done it before. And I did not need to replace the o-ring gaskets, although I did take the time to clean them up and hit them with a coat of paint.
txironhead is offline
