Need help removing ignition switch. - Honda Shadow Forums : Shadow Motorcycle Forum
Old 06-21-2010, 01:51 PM   #1 (permalink)
Default Need help removing ignition switch.
I am stuck on this step. How do I remove these round bolts? Or do I have to remove them? The manual's picture is also there in the "photostream" on the right side of webpage.
http://www.flickr.com/photos/9838830@N08/4721147209/
What do you call a cyclist who doesn't wear a helmet? An organ donor. ~David Perry
txridr is offline   Reply With Quote
Old 06-21-2010, 02:20 PM   #2 (permalink)
Can you reach around the back of those round bolts to see if you're seeing the bottom of them?
If the two hex heads at the right are removed, can you get those round ones out?
DISCLAIMER: I've not done this before, I'm just speculating based on the pictures.
1999 Yamaha V Star 1100 - Honorary Honda Shadow
Croz is offline   Reply With Quote
Old 06-21-2010, 05:32 PM   #3 (permalink)
The local Honda dealer referred me to a local locksmith since they don't cut keys there.
Those are headless bolts that are permanently in place.
The code is stamped on the outside of the cylinder: three numbers, a letter, then three numbers (123J456)
Got two keys for $40; It was $35 for one.
Time to start ridin'.
Mauro.
Old 06-21-2010, 05:57 PM   #4 (permalink)
RedClayRider's Avatar
According to my Clymer manual, those are "break-off bolts". It says to center-punch the bolts, then drill off the bolt shanks with a hand drill. It earlier notes that you should purchase new ignition switch break-off bolts when ordering the switch.
Please note that I'm not telling you drill out the bolts, but that's what the Clymer manual seems to say.
Good luck!
-redClayRider
2002 Spirit VT750DC
-RedClayRider
RedClayRider is offline   Reply With Quote
Old 06-21-2010, 06:52 PM   #5 (permalink)
cycleheart1100c's Avatar
Send a message via MSN to cycleheart1100c
Do you have a dremmel or a small die grinder with a cutting wheel? You can cut a slot in the exposed portion and remove them with a screw driver.
Cycleheart
05 spirit 1100
Northern Utah
PGR
cycleheart1100c is offline   Reply With Quote
Old 06-23-2010, 01:50 PM   #6 (permalink)
Default Shoot!
Found the damn key: http://www.flickr.com/photos/9838830@N08/4727478239/
It was in a short's pocket. Looked in all my pants, but not my shorts.
Well, at least I have spares now.
Old 06-24-2010, 09:51 AM   #7 (permalink)
Honda has for many years use special "breakaway" screws to mount ignition switches on most of the vehicles they make. When installed the heads snap off at a predetermined torque value making it difficult for thieves to access the switch's wiring. To replace the switch they tell you to carefully drill out the old ones, new breakaway screws are included with the switch from the dealer. The last couple I had to replace I torqued just enough to secure the switch but stopped short of snapping off the heads so I could remove it again if necessary. A clever idea but I don't think it would stop a determined thief.
A 9m is a .45 set on stun
Drail is offline   Reply With Quote
Old 11-20-2012, 09:08 AM   #8 (permalink)
I used a hex key to get these off. Worked fine. If you ever need to do this again go to a hardware store and look for a hex key set
ngc316 is offline   Reply With Quote
