Spark plug removal - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 23 (permalink) Old 07-10-2010, 10:30 AM Thread Starter
Spark plug removal
2002 Honda shadow spirit 750. The spark plugs that are under the plastic covers are impossible to get a socket on due to the angle and limited space. Is there a special tool required to get to these spark plugs? Tried several different deep well socket and none with work.
Thanks
Andy
mink is offline
post #2 of 23 (permalink) Old 07-10-2010, 10:37 AM
18 mm thinwalled deepwell
Afghanvet_2x is offline
post #3 of 23 (permalink) Old 07-10-2010, 10:52 AM Thread Starter
Thanks for the info. How much difference in O.D. is there btween regular and thin walled? It's is a pretty tight fit. I will try the thin walled socket.
mink is offline
post #4 of 23 (permalink) Old 07-10-2010, 12:33 PM
h13man's Avatar
Enough. I got mine @ Rural King. Stk. #3718 which is 15/16" in dia.
71' CL 100
99' Valkyrie
Ride Bell by "Yoman"
h13man is offline
post #5 of 23 (permalink) Old 07-10-2010, 05:55 PM
Posts like this make me wonder what happens to all of the OEM tool kits that came with the bike. Do people throw them away or what? Or do they go to the same place where the other sock went to? I have not found anything better to use than the cheeseball Honda plug socket that came with my bike. Craftsman 18mm 12 point deepwell will work also.
A 9m is a .45 set on stun
Drail is offline
post #6 of 23 (permalink) Old 07-11-2010, 04:00 PM
Re: Spark plug removal
Thanks
Andy
had the same problem with mine, found the sparkplug socket from a kawasaki fit great it has a taperd end with a swivel on the end mad it so easy. hope this helps.
Wolfman69 is offline
post #7 of 23 (permalink) Old 07-11-2010, 07:08 PM
+1 Thats what the tool kit socket is for.
simpleman77 is offline
post #8 of 23 (permalink) Old 07-12-2010, 10:33 AM
I am a user of the one in the toolkit. Works just fine. I put a socket on the end to use a ratchet with it with no issues.
1998 VT1100T A.C.E. Tourer
cl65ame is offline
post #9 of 23 (permalink) Old 02-17-2014, 05:46 PM
I had the same problem. Go to lowes and get Kobalt 3/8 drive, 12pt, 18mm deep well. $5
2006 SS750
ccellison is offline
post #10 of 23 (permalink) Old 02-17-2014, 06:59 PM
When I bought my bike (used) the tool kit in the took kit spot (under the seat in a little plastic box) contained 1 8mm wrench, a screw driver handle with a reversible screw driver bit, a socket driver and 5 sockets, 6-10 mm. I ordered an OEM plug socket on Ebay for $20.
2009 Shadow 750 Aero.
Memphis Shades Fats windshield
Tri pouch
Lizard Lights
Leatherlyke hard bags
Boss MC400 stereo.
If it doesn't challenge you, it doesn't change you.
PapaJ42 is offline
