Anyone know if buying a carburetor synchronizer is a good investment. And if so, where and which model to buy. Thanks.
What do you call a cyclist who doesn't wear a helmet? An organ donor. ~David Perry |
Not sure if it is necessary but feeling that I had to remove and clean my carbs I purchased a Morgan Carb Tune as was recommended by someone here.
I didn't want to make my own.
![]() 2004 Spirit 1100 |
#3 (permalink) |
Hey txridr, where ya located?? I have a homemade one, made from instructions I got from HS, and I also have the tubes that screw in the ports, (tubes are for a 1100 gotten from markc).
Mike & Judi SCRC TX Ellis County
#4 (permalink) |
http://www.huntforfood.com/manometer.php
http://www.motionpro.com/motorcycle/partno/08-0013/ It's not much of an investment, the total cost to DIY is under $20. I sync my carbs once a year. It really doesn't take that long to do. |
#5 (permalink) |
Good investment? Depends on whether or not you're going to use it. Generally, I only check carb sync once a year (about 7k miles) and don't need to adjust it every time.
With a V-twin, making your own is probably better. If that's too much to take on then you probably wouldn't use it. I've been using a 4-cylinder one that I bought years ago for the 4-cylinder bike I was rebuilding at the time. I really don't like the way it works on my V-twin so I've bought the tubing I need to build my own 2-cylinder version (as per the instructions linked above).
#6 (permalink) |
You can buy this one on ebay for $90 after shipping... I've been meaning to get one for a long while. I rebuilt my carbs a few months ago and have just been too broke to buy the manometer. I think I'm going to try to build my own. I just hate going the cheap route only to have to go the expensive route later, but it sounds like some people even prefer this method over a true manometer.
1984 Honda VT700c Shadow Tired of scrolling past all the stickies in the Tech forum? Join the discussion in the "Discuss this Website" Forum |
#7 (permalink) | |
Go for a homemade model-no worries I balance my FI Vstroms (throttle bodies) and several of the natually aspirated V-twins in stable. Never an issue. |
#8 (permalink) | |
#9 (permalink) |
How about this?
Some syncro's I see are 2 or 4 gauges (vacuum) on plate, with hoses. Why couldn't a guy go to say AutoZone, and "rent" (free when returned) 2 big 3" diameter gauges, use his own fittings, and have NOTHING setting around the garage being used 1 day out of a year, or so? Maybe even switch the gauges on each cylinder to be sure they are "calibrated"....ie "read the same" before "trusting" them for the syncro job. Input appreciated, I personally have not done this.
95 VT1100C Stock Air box (UNI-Filter), HK's, River Road XL Slant Braided saddlebags, 6 degree Timing Advance, Mustang Wide Touring w/ Driver Backrest, PF3 Windshield, Chrome Engine Side covers, Lower forks, Final drive, Driveshaft, Swingarm, Master Cylinders, Brake caliper 1983 VT750C 1983 VF1100C Magna
#10 (permalink) | |
Has everyone seen this thread in the stickys above? Carbs Synched - big thanx!!! (w/some pix) Last edited by Cbjr; 02-06-2011 at 09:59 AM. |
