1987 Honda shadow Carburetor reinstall? how? - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 4 (permalink) Old 07-25-2010, 04:08 PM Thread Starter
Ok Guys I managed to get the carbs out but had to get new carb boots..
I rebuilt the carbs.. and replaced boots..
But can someone tell me whats the trick to getting them in?
Boots on bottom first? then cant install uppers.. No room between engine and the top rubber mounts to breather box..
This box is part of frame! What a bear!! Gotta be a trick to this..
Any advice would help much!
Thanks to all for advice!
pcnut45840 is offline
post #2 of 4 (permalink) Old 07-25-2010, 05:22 PM
tubes_rock's Avatar
What 1987 model?
--Justin
Currently Running Stable:
2010 Honda NT700V
1986 Shadow 700
1987 Honda Rebel 450
1973 Honda Mini Trail 50
tubes_rock is offline
post #3 of 4 (permalink) Old 07-25-2010, 10:02 PM
tubes_rock's Avatar
Got thinking about it...
If yours is a 700, then this thread might help!
http://www.hondashadow.net/forum/viewtopic.php?t=82612
--Justin
2010 Honda NT700V
1986 Shadow 700
post #4 of 4 (permalink) Old 07-26-2010, 03:37 AM
gentlemanjim's Avatar
Install the boots on the cylinder heads first. Spray or wipe a little armorall on the lips. Set the carbs in place and push down usually one will start to pop in. put a piece of wof wook ofver the inlet and use (gently) a pry bar between the frame rail and lever it down with very little pressure and they will pop right in.
More Wrenching than Riding
- '83 Shadow VT750C
- '83 Yamaha XS650R
gentlemanjim is offline
