VT500c gravity fed petcock. Had an air sucking sound coming from the hose that goes from the petcock to the engine on the lefthand side. Small crack in the hose little tape and issue went away.
Started again this morning, got that sucking sound and bike would not idle. More tape lol and moved it around a bit and ran fine at idle and speeds. I will replace the hose tonight, what type of material should I get? Is a special kind needed to withstand the engine heat? Also what does that air hose do? Does the engine start and then use it as a vacuume to help pull the fuel from the tank down into the carbs? Thanks Crash
![]() 1984 VT500C Shadow Ox Blood Red |
The hose uses engine vacuum to operate the diaphragm in the automatic petcock. Vacuum opens the valve and lets fuel flow to the carbs. Replace the line and you will be fine. I used some 3mm ID high temp silicone because that's what I had laying around, but you shouldn't need anything fancy. Rubber vac hose or fuel hose will do as long as the inner diameter (ID) is small enough. 3mm or 1/8" should do.
#3 (permalink) |
The hose is a vacuum line from the engine intake to the petcock.
The petcock is an "automatic" valve that is vacuum operated to let fuel go from the gas tank to the carbs. Take the old hose to an auto parts store. They can match the diameter and sell you the length you need. With a leak in the hose, the petcock won't open to feed the carbs. Also the engine may run poorly due to the extra air being sucked into the cylinder. While you are working on the petcock area, you may want to test the petcock. With no vacuum, there should have no gas flow in any of the 3 positions. With vacuum (you can suck on the hose enough to open the petcock), there should be gas flow in the ON and RES positions, but no gas flow in the OFF position. Ride safely,
1983 Nighthawk 650 1989 VTR250 1985 Sabre 700 - - Sold 1983 Shadow 500 - - Sold 2006 Ninja 500- - - - Sold |
#4 (permalink) |
Thanks for the info.
I was going to stop by the store on the bike so I don't have the tube off yet and its kinda stuck on good so i may have to cut it off. The schematics for the hose say 3.5X75. Is that 75mm long with a 3.5 internal diameter? Thanks Crash
