How much oil for a 1999 Shadow? - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 5 (permalink) Old 09-23-2010, 12:43 PM Thread Starter
How much oil do I put in my 1999 Honda Shadow 750? Also, what type of oil do you recommend?
rodsgirl is offline
post #2 of 5 (permalink) Old 09-24-2010, 09:59 AM
Pretty much any 10W40 oil is fine to use. Read the oil thread at the top of the page for more info.
As far as amount. Get 4 quarts. Put in two and check the dip stick then add a little more and repeat until between the lines on the dip stick. Maybe some one with a 1999 will chime in with the exact amount. Check with bike level and dip stick not screwed in but just resting in hole.
Welcome.
Three things that are not long hidden; the sun, the moon and the truth.
2005 Aero
1972 Honda XL250 Motorsport
2006 Rebel - daughter (Now gone)
1974 XL100
thunderglass is offline
post #3 of 5 (permalink) Old 09-24-2010, 02:43 PM
Only thing to add - make sure the API label on the oil you select does not contain the words "Energy Conserving".
Cbjr is offline
post #4 of 5 (permalink) Old 09-26-2010, 04:36 PM
my 2000 ACE 750 uses 3 qrt with a filter change.
ghostrider
ghostrider460 is offline
post #5 of 5 (permalink) Old 09-26-2010, 05:44 PM
No. If it has the API Circular label on it AT ALL. Don't use it.
For a wet clutch application such as a Honda Shadow you need to confine to SF/SG grade oil ONLY.
I started using Valvoline 4-Stroke Motorcycle Oil and it works fine.
Honda does not recommend using Castor based oils or synthetics. Stick to Dino oil.
I just went through this and it almost ruined my clutch.
-- Mark
'98 Shadow 1100 ACE
Notorious is offline
