1995 VLX600 Gold / Silver flakes in oil, - Honda Shadow Forums : Shadow Motorcycle Forum
Old 10-26-2010, 10:01 PM   #1 (permalink)
Default 1995 VLX600 Gold / Silver flakes in oil,
I drained my oil again after 2,000 miles and noticed gold and silver flakes in the bottom of the pan. These flakes are not attracted to a magnetic source, so I do not think they are metal. One side of the flake is gold in color and the reverse side is silver in color. When placing the flake in your hand, the flake breaks in half. Does not feel like metal either. I do not know what is breaking down inside. Is there anytype of coating that could be breaking down inside the motor to cause these flakes.
dannyboy is offline   Reply With Quote
Old 10-27-2010, 12:02 AM   #2 (permalink)
That's very weird.. My friend just bought an 85 shadow so I will be interested in findind out what this stuff is.
shadowmib is offline   Reply With Quote
Old 10-27-2010, 02:17 AM   #3 (permalink)
Put some heat to the flakes, if they melt it could be the cam tensioner going south on ya.
Ted
Old 10-27-2010, 07:27 AM   #4 (permalink)
tubes_rock's Avatar
How big are these flakes? Little metallic particles are somewhat normal, since that's the little bits of the clutch suspended in oil. That's normal for the particles to get in the oil as the clutch wears. Usually the oil filter traps them all, but it's not uncommon to see a few in the oil here and there. But if they're bigger than a spec of dust, this is not normal.
--Justin
2010 Honda NT700V
1986 Shadow 700
Old 10-27-2010, 09:20 AM   #5 (permalink)
Lou Pietrandrea's Avatar
this is reaching a bit.....but what about the oil filter itself? What kind of filters have you been using and have you tried disecting a used filter to see if there are any of those particles on the trapping side of the filter?
96-VT1100C (other bike is an '81 kaw KZ)- I am not required to know everything....I am only required to understand what I know...
Lou Pietrandrea is offline   Reply With Quote
Old 10-27-2010, 09:39 AM   #6 (permalink)
Blackstone Labs can tell you what it is.
http://www.blackstone-labs.com/
callmeal is offline   Reply With Quote
Old 10-27-2010, 10:49 AM   #7 (permalink)
The flakes in the oil are larger than a spec of dust. I am going to send the oil sample in to see what they say. Thanks for the info
Old 10-27-2010, 09:33 PM   #8 (permalink)
if they are gold on one side and silver on the other then it is bushing / bearing material wearing. The lab will define exactly what it is.
If the flakes are large then you are looking at pulling the motor and replacing bearings.
1998 VT1100T A.C.E. Tourer
cl65ame is offline   Reply With Quote
Old 11-02-2010, 11:31 PM   #9 (permalink)
Some people told me that it may be bushings / bearing material, but the flakes are not metalic, they do not appear to be of metal material and are not attracted to a magnet.
The flakes break apart in your hand very easy, they feel like paint chips / paper like material. If it was bearing material, would the flakes be metal???
I am sending the used oil into the lab, but the lab said they could not tell me what the flakes were, just what is in the oil.
Thanks for any advise.
I was thinking that the gold color was coming from this source. Please see the attached photo. What do you think?1995 VLX600 Gold / Silver flakes in oil,-engine.jpg
1995 VLX600 Gold / Silver flakes in oil,-engine1.jpg
Old 11-02-2010, 11:38 PM   #10 (permalink)
You do know that many metals (such as aluminum and bronze which are commonly used for bearings) are non-ferrous, meaning they won't be attracted to a magnet, right? RIGHT?
jagojon3 is offline   Reply With Quote
