3rd post/ gear shifting question - Honda Shadow Forums : Shadow Motorcycle Forum
Old 04-17-2012, 11:42 PM   #1 (permalink)
Default 3rd post/ gear shifting question
I have a 2004 shadow vt750 and I was wondering about what speed I should be shifting gears. Like a manufacture recommendation or something. Thank you.
Narcolepticpug is offline   Reply With Quote
Old 04-17-2012, 11:48 PM   #2 (permalink)
Simple
It should be in your owners manual (sorry I sold mine with my bike)
Or you could trust the public domain? The link below should have your answer.
Let me google that for you
2012 Victory Vegas 8-Ball
spicoli512 is offline   Reply With Quote
Old 04-17-2012, 11:51 PM   #3 (permalink)
Originally Posted by spicoli512 View Post
Simple
I bought my bike used. No manual. And I tried googling it. And couldn't find it.
Edit: clicked the link... I guess I just googled the question wrong... Thank you
Couldn't really find exactly what I was looking for though
Old 04-17-2012, 11:54 PM   #4 (permalink)
NOTE this is for the VT750C2 (shaft drive) I would assume it would be similar. Ultimately it comes down to feel.
From the Manual courtesy of Google
Recommended Shift Points
Ride in the highest gear that lets the
engine run and accelerate smoothly. This
will give you good fuel economy and
effective emissions control. When
changing gears under normal conditions,
use these recommended shift points:
Shifting Up -
From 1st to 2nd:
From 2nd to 3rd:
From 3rd to 4th:
From 4th to 5th:
12 mph (20 km/h)
19 mph (30 km/h)
25 mph (40 km/h)
31 mph (50 km/h)
Shifting Down
From 5th to 4th:
From 4th to 3rd:
From 3rd to 2nd:
28 mph (45 km/h)
22 mph (35 km/h)
16 mph (25 km/h)
Pull the clutch lever in when speed drops
below 9 mph (15 km/h), when engine
roughness is evident, or when engine
stalling is imminent; and shift down to 1st
gear for acceleration.
Old 04-18-2012, 12:14 AM   #5 (permalink)
Awesome. Thank you. I saw Somthin similar to that, but wasn't sure if it was different being a different bike.
Old 04-18-2012, 01:05 AM   #6 (permalink)
LannyNguyen's Avatar
I don't even follow that.
It all depends on what mods you got on your bike and how your bike is tuned.
Also depends on weight of rider, and if they have a passenger.
Also windshield and weather affects it too.
I normally go on how I hear the engine and the throttle. Very easy.
2006 Honda Shadow Aero Bagger
LannyNguyen is offline   Reply With Quote
Old 04-18-2012, 07:56 AM   #7 (permalink)
Harvey's Avatar
My bike won't shift into 5th at 31mph unless it's forced to do so. It only goes into 5th easily at 50mph. The dealer will not admit there is a problem, under warranty of course.
Shadow RS Facebook Page
Harvey is offline   Reply With Quote
Old 04-18-2012, 08:13 AM   #8 (permalink)
The shift points are also determined by the situation. If you shift into 5th at 31 mph while getting on a busy expressway you may be in trouble as you wont have the acceleration you need to merge safetly.
dgraves49 is offline   Reply With Quote
Old 04-18-2012, 08:21 AM   #9 (permalink)
nraluke's Avatar
+1 Where that chart has them going into 5th gear, I'm going into 3rd gear and thats not pushing the RPMs. Usually i don't hit 5th until around 50 MPH.
nraluke is offline   Reply With Quote
Old 04-18-2012, 09:07 AM   #10 (permalink)
SnoGhost13's Avatar
Hard shifting can be caused by old oil. Try doing an oil change if it hasn't been done recently and see if it helps.
Sent from my Samsung Epic 4G Touch using Motorcycle.com App
Joe
08 VT750C2 Shadow Spirit
SnoGhost13 is online now   Reply With Quote
