3rd Post & Problem Feedback Request - Honda Shadow Forums : Shadow Motorcycle Forum
Old 11-05-2012, 10:45 AM   #1 (permalink)
emmazoemom's Avatar
Question 3rd Post & Problem Feedback Request
Hi there, it is me again with my 3rd post. I have only had my new-to-me 2006 Shadow Spirit 750 for 1 week, but I have had a problem arise already (and I am sad).
I use my bike for a daily commuter, about 20 miles each way). 3 times in the last week my bike just died on I-5. The first time, I thought I ran out of gas (looking back on it, I did not). The second time, I noticed that it felt like a loss of power. The 3rd time (3 miles later), it felt the same way - loss of power.
The last two instances happened just yesterday afternoon. The 1st time, I thought I had run out of gas like the time before. I opened the tank and it was over 1/2 full, so that was obviously not the issue. Given that, I tried starting it again. It was rough, but started, so off I went.
Exactly 3 miles later, the same thing happened. Knowing that I had gas, I tried other things. This time I flipped the kill switch on and off once. I tried restarting it and it worked and I made it home with no problems.
My husband looked this up last night and found that it was a fairly common problem with this motorcycle and that the general thought is that this issue lies with the kill switch.
Is anyone aware of a true fix for this problem?
Thank you, Becky
emmazoemom is offline   Reply With Quote
Old 11-05-2012, 12:59 PM   #2 (permalink)
Super Moderator
old dad's Avatar
Start simple, check your battery connections, good and tight? ,,is the battery holding a charge?
2006 vlx
Old 11-05-2012, 05:01 PM   #3 (permalink)
emmazoemom's Avatar
It is a new battery and I know the connection is good as I had to do some work on it. My husband checked it too yesterday, all is well.
Becky
2006 Honda Shadow Spirit VT750
Old 11-05-2012, 05:07 PM   #4 (permalink)
Ive never heard of kill switch problems - and the first thing I was going to say was to check the battery as well.
Same thing happened to me when I first got my 1100. Left hand turn and suddenly the bike shut off. Only happened in left hand turns. Turned out to be a loose battery terminal and when I turned left, the battery shifted just enough to cut power. Loctited that bizzy in there and never had that problem again... And I never would have known it was the battery from a visual check. I literally had to use a wrench to lock that puppy down.
2003 Victory Vegas - 92 cu. in., Mustang seat, straight pipes, K&N filter, remapped ECU, powder coated wheels/foot controls/hand controls/handlebars/ rear pulley/rear luggage rack. Digital speedo/tach with powder coated housing.
So-Crates is offline   Reply With Quote
Old 11-06-2012, 01:31 AM   #5 (permalink)
Exact same thing happened to me yesterday. I noticed that after I got it to fire back up my digital tripometer had reset to zero. That leads me to believe it was a complete loss of electricity. Did you notice if yours did that?
Sent from my PC36100 using Motorcycle.com Free App
07 Aero 750
Mustang seat
M/C Enterprises floorboards
Heel/toe shifter
DarkAero is offline   Reply With Quote
Old 11-07-2012, 02:21 PM   #6 (permalink)
emmazoemom's Avatar
I haven't had a loss of power, it just feels that way.
Yesterday after work, it wouldn't start. I flipped the kill switch several times and it finally started.
I will be happy to check the battery again and report back.
Thank you!
Becky
Old 11-07-2012, 02:52 PM   #7 (permalink)
cvaria's Avatar
Thank you!
Check the fliud level in the battery every 3 months. I think you may want to do a self tune-up (replace plugs and oil) and then seafoam in the gas.
If none of that works then maybe some carb balancing and fun stuff like that.
you are opening the the petcock, right?
I still do that, i'll get to riding (ine-c, what f?) and then put put put... (O_o).... look around wondering what happened, the look down in shame at the off petcock. this usually happens in traffic when i'm in front at the light.... end up crab walking the bike off the road and bouncing around to get the fuel going.
I like my 2003 Z4 2.5i (for sale: $13000 obo), love my 2002 Wrangler SE and my 1986 VT500c (for sale: $1200 obo), and i have an affair with my 2007 Sportser 883! (clearly time to leave the condo and get a house)
Current collection:
cvaria is offline   Reply With Quote
Old 11-07-2012, 03:02 PM   #8 (permalink)
Super Moderator
old dad's Avatar
folks always jump into heavy mechanics, not always needed,,has the tank been off, is it possible that a fuel line got crimped or pinched? I have said before start simple. It's usually the little things. I'd check the connections on the kill switch too, it may just need cleaning.(there is a thread on switch cleaning, though it's on the turn sig. switch)
Switch cleaning 101
2006 vlx
Old 11-08-2012, 10:09 AM   #9 (permalink)
emmazoemom's Avatar
Well, yesterday it died, died, died on I-5. Fun, fun, fun. It was towed to the shop where they were able to quickly determine is wasn't the carb, but they aren't sure what it is. Of course after 3 hours of not starting, it started right away for the tech (Murphy's Law, right?).
They are trying to replicate the problem (shouldn't be hard) and to go from there. Needless to say, I am cranky cause I had to ride the bus and don't have my bike. Ugh! I want my bike back and the problems to go away. I wish I knew more myself.
Thanks for listening to me whine. I will be serving cheese later...
Becky
Old 11-08-2012, 10:58 AM   #10 (permalink)
joe in calif's Avatar
Sounds like the kill switch as you think. They can get dirty, you can take it apart and spray contact cleaner in it, DO NOT USE WD40. There was a recall on the kill switch on the Gold Wing a few years back so it's not unheard of. I'm not real familiar with the shadow but on the Gold Wing there is a bank angel sensor, if that fails the bike will only start if you turn the bike off and on again. let us know what the shop finds.
Have you checked your fuel filter? If it gets plugged the fuel flow will stop and after a short time the junk will float to the bottom of the filter and the bike will run again, for a short time.
IF YOU ARE BORN ONCE YOU WILL DIE TWICE
IF YOU ARE BORN TWICE YOU WILL DIE ONCE
joe in calif is offline   Reply With Quote
