My Sabre has a turn signal issue.... They work sometimes.. I have cleaned the switch, i need to check the relay...
Is there anything else I might need to check?? Thanks for any help.... |
I would press the switch and listen to the relay. If you don't hear the steady metronome of "click...click....click" then you probably need a new relay. If your switch is clean especially. Other than that? The bulb itself maybe...
1996 Honda Shadow VLX 600 Red/Black ![]() |
#4 (permalink) |
Well, the bike sat outside for a couple months.... I recleaned the switch, but no turn signals.. Yes it is both sides...
Can anyone tell, me where the relayt is located?? and No I do not hear the tick tick tick.. Thanks for the responses.. |
#6 (permalink) |
ok, so I went as far as taking the switch apart and cleaning it, it is getting current when turned on... the relay is not clicking, front light goes out, no rear light.. Power at relay.. checked all grounds.. last resort are the bulbs?? Unless someone can help me out here... Am I missing anything??
#7 (permalink) |
You did not tell us what year it is, New or used ? I have seen bikes that people have installed LED bulbs in them, do the same thing you are describing. Have you looked at / tested the bulbs ?
VT-1100C2 Vance & Hines Long Exhaust . K&N air filter |
#9 (permalink) |
Its a 2006 sabre, new to me... no led bulbs... I have not check the bulbs yet. I will be checking them on my break today..
2006 Shadow Sabre 1100, 5" risers, stebel air horn, led bulbs in turns and fog lights... more upgrades to come. 03 Odyssey 98 CRV The Honda Family... Watch out for cars... they're everywhere... |
#10 (permalink) |
bulbs checked out ok.... still no turn signals... The front running lights come on, and when you hit the switch, it goes out..?
all corrosion free..
