Help! After first ride, my shadow won't start! - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 15 (permalink) Old 05-16-2017, 08:40 PM Thread Starter
So what's happened: bike got dropped off, it's safetied and certified (I'm in Canada) - I turned it on, did just fine! Rode it around the block (big block) - just fine. I parked it. Tried to turn it back on. I hear a couple of clicks and that's all - biked won't start. Any ideas? I'm running a trickle charger on her right now. Will see what happens after that.
Mel Racho is offline
post #2 of 15 (permalink) Old 05-16-2017, 10:37 PM
swifty2014's Avatar
First wiggle the battery terminals to see if they are clean and tight. I would call the dealer if that is where you got it and ask their opinion on what to do.
To eliminate a battery problem just jump it with a car battery that way you can see how well the system will work with plenty of crank amps. Maybe a weak cell in the battery that failed when it got hot. If you have a meter put it on the battery and when it is running see if the charge voltage gets up to 13.5 to 14.5 when revved up to 3000 RPM.
1983 750 Shadow
From the past=
1951 Cushman scooter
1962 Honda 305 Dream
1965 Honda 305 Dream
1971 Honda 175 scrambler
swifty2014 is offline
post #3 of 15 (permalink) Old 05-17-2017, 08:57 AM
Nuh_auni's Avatar
Side stand switch malfunction took mine out going down the road once, I had to disconnect it and wire it back onto itself so it would read as up.
Or maybe you left the killswitch in the off position? I do that all the time.
Sometimes it seems like I'm arguing, that's just how I work out a solution:.. Other times I'm arguing.
'Grace' 03 Shadow Ace Deluxe VT750CDA
05 Shadow VLX 600 VT600CA
Nuh_auni is offline
post #4 of 15 (permalink) Old 05-17-2017, 10:05 AM
If clicking it is not the kill switch. Check battery connections and then test battery.
gdb069 is offline
post #5 of 15 (permalink) Old 05-17-2017, 11:39 AM Thread Starter
Thanks all. Following what I read here - I went and kept it connected to a trickle charger all night and it started this AM. I've read that bike needs to be 9000 rpm to charge the battery. Just worried that each time I ride it the battery is gonna die unless I get it up to 9000, will try to build my confidence up to do so
post #6 of 15 (permalink) Old 05-17-2017, 12:03 PM
Nuh_auni's Avatar
The starter won't, you're right, but...
PO wired aftermarket lights onto mine, when I hit the starter with the kill switch engaged they lose power, and click when they comeback on.
Sent from my SM-G925P using Tapatalk
Nuh_auni is offline
post #7 of 15 (permalink) Old 05-17-2017, 12:12 PM
swifty2014's Avatar
NO WAY 9000 RPM don't do that. Maybe 3000 RPM is more like it. But they don't charge much at idle.
1983 750 Shadow
From the past=
post #8 of 15 (permalink) Old 05-17-2017, 12:47 PM
Scared's Avatar
I'm sure they won't charge after 9,000 RPM's because there would be pieces of motor all over the place.
http://i997.photobucket.com/albums/a...C64070057F.jpg
2002 750 ACE DELUXE: Sold
2003 BMW K1200GT
Ride Bell by Old Dad
Ride Bell by Gnarly
Ride Cross by "Captain D"
Scared is online now
post #9 of 15 (permalink) Old 05-17-2017, 12:57 PM
swifty2014's Avatar
I like some of these videos of failures to help appreciate what our engines go through at high RPMs.
1983 750 Shadow
From the past=
post #10 of 15 (permalink) Old 05-17-2017, 03:35 PM
It should start charging between 1200-1500 rpms. If it was 3000, a lot of us would be running our batteries down a lot.
jpr1968 is online now
You may post new threads
You may post replies
