My project - resurrecting my "new to me" shadow ace - Page 6 - Honda Shadow Forums : Shadow Motorcycle Forum
post #51 of 65 (permalink) Old 07-13-2018, 11:42 AM Thread Starter
birey140's Avatar
Worked on it some more - finally got the carburetor off the bike, and now to get it cleaned up. That was a pain in the ass! Fortunately, my 4 year old son was at daycare when I finally got it removed, otherwise he probably would have learned some new cuss words lol
birey140 is offline
post #52 of 65 (permalink) Old 08-06-2018, 10:03 AM Thread Starter
birey140's Avatar
So the carb has been removed, rebuilt, reinstalled (after much frustration and cursing). Still running into issues w it stalling out. Thoughts? Ideas? Short of pushing the damn thing in the road and saying screw it?
birey140 is offline
post #53 of 65 (permalink) Old 08-06-2018, 10:26 AM
MtnDweller's Avatar
Model: VT1100C
Year: 1993
Well I wouldn't say screw it after all that you've been through together. It seems to be that it may be a faulty ignition coil or a timing issue. But i am just getting started on my build so I am learning a lot right now. it idles okay? Is it only when putting it under a load? uphill etc.?
1993 Shadow VT1100C
Mods forthcoming
MtnDweller is offline
post #54 of 65 (permalink) Old 08-06-2018, 10:30 AM Thread Starter
birey140's Avatar
Lol oh itís tempting to but I will not let this damn bike get the better of me.
When you go to start moving and put it under load it will stall out. Idles just fine. You can even throttle up in neutral just fine. Just seems as soon as you try to put it in gear and it goes under a load it will stall. One thing a buddy of mine suggested just a few moments ago when I was picking his brain, was to make sure there wasnít slack in the throttle cables from when I reattached them to the carb. I thought I had them ďtightĒ but gonna double check to make sure there isnít any excess slack. Prob gonna do the same to the clutch cable since I recently replaced that as well.
birey140 is offline
post #55 of 65 (permalink) Old 08-06-2018, 10:51 AM
MtnDweller's Avatar
Model: VT1100C
Year: 1993
Is your battery staying charged? If it draining you could have a faulty stator.
1993 Shadow VT1100C
Mods forthcoming
post #56 of 65 (permalink) Old 08-06-2018, 11:09 AM Thread Starter
birey140's Avatar
Battery is good. I keep it on a trickle charger when itís parked.
birey140 is offline
post #57 of 65 (permalink) Old 08-06-2018, 11:16 AM
MtnDweller's Avatar
Model: VT1100C
Year: 1993
If you have a voltmeter I would check the producing volts when running. it should read somewhere around 14V at 3K RPM if the stator is working right. At least that would eliminate the possibility.
1993 Shadow VT1100C
Mods forthcoming
post #58 of 65 (permalink) Old 08-06-2018, 11:21 AM Thread Starter
birey140's Avatar
Sounds good. Will check it.
birey140 is offline
post #59 of 65 (permalink) Old 08-06-2018, 12:31 PM
Year: 2000
You said in the opening post... "A project I am looking forward to, as this is my first bike"
Have you tried letting someone who already knows how to operate a motorcycle try riding it?
Chuck_Michigan is offline
post #60 of 65 (permalink) Old 08-06-2018, 01:15 PM Thread Starter
birey140's Avatar
Lol I have considered operator error as part of the problem (and partly may be) Although itís the first one I have owned I have ridden dirt bikes etc, as well as it has been ridden around the neighborhood on test drives as it was being brought back to life.
birey140 is offline
resurrecting 84 VT700c thread RocksBlues General Bike Discussion 15 02-27-2013 04:00 PM
86 VT1100, modded seat, took me from "I think I'll sell it", to "I love this bike" Buicknick72 General Bike Discussion 5 02-20-2012 09:53 AM
My "New to Me" 98 ACE Deluxe AbdominalDohMan Member Introductions 0 05-15-2011 08:48 AM
resurrecting the dead 2T2 Crash Technical Discussion 2 06-27-2010 04:36 AM
Be Seen"""LQQK"" SHADOW 1100T General Bike Discussion 9 04-27-2008 06:04 PM
