A lift to work on a vt600 ? - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 6 (permalink) Old 07-21-2016, 11:44 PM Thread Starter
I am working on a bike that hasn't been started in 7 years. I am making progress. ( though it hasn't been without a setback) . I should be ready to try to start it on Sunday.
I'd like to know what you use to lift the bike off the ground to do things like oil/filter changes or chain lubing. Is there a good inexpensive lift?
Or another way?
Any comments would be appreciated .
MarlboroMan is offline
post #2 of 6 (permalink) Old 07-22-2016, 12:07 AM
smilie's Avatar
You can get a used harbor freight or similar hydraulic lift for $40-60.00 all day long. Most will need you to make some sort of adapter to work around the protruding engine or exhaust below the frame. Can be done though. I've made 2 different ones for my lift so far. And BTW, you don't need to lift the bike to change oil. In fact it's supposed to be done with the bike on the sidestand.
smilie is online now
post #3 of 6 (permalink) Old 07-22-2016, 12:30 AM Thread Starter
Thanks.
It's a 2004 shadow vlx, vt600c.
Glad to hear that For oil/filter change I should used the sidestand, since I am planning on doing that tomorrow.
Are the lifts sturdy? The bike won't fall?
post #4 of 6 (permalink) Old 07-22-2016, 12:45 AM
smilie's Avatar
As long as the bike is secured, it's fine.
post #5 of 6 (permalink) Old 07-22-2016, 03:00 PM
Steve D.'s Avatar
Motorcycle lift. Sears. Sears.com
Use it on my ACE all the time. It works on the VLX too. I have not had it topple over yet. Great little lift.
Steve D. is offline
post #6 of 6 (permalink) Old 07-22-2016, 08:23 PM
jwinker's Avatar
Literally, the EXACT same jack HF sells, just different colors & different store.
1500 lb. Capacity ATV/Motorcycle Lift
Whichever you choose, get some ratcheting tie-downs with it. You can use the straps to secure the bike to the jack and hold it tight while you work on it. You can get pretty aggressive with the bike without fear of it tipping over.
Either way, what's your location, @MarlboroMan ? Maybe someone has one you can borrow?
There's no such thing as "Spare Time" or "Free Time" or "Down Time."
Time is time. All you have is "Life Time." GO.
-- Henry Rollins
jwinker is offline
Best way to lift bike for tire work? Epeescott Technical Discussion 17 09-24-2013 11:44 AM
Lift For VT600 CD KennyG Technical Discussion 4 10-04-2012 12:50 AM
2001 vt600 vs 2005 vt600 parts kitdog Technical Discussion 0 04-06-2011 05:53 AM
I hate work, I hate work, I hate work, I hate work. Mike R. General Bike Discussion 14 06-27-2008 09:41 PM
Will this DynoJet work for a 93 VT600 Shadow TvnShdadow Technical Discussion 0 01-11-2008 04:13 AM
