Opinions - electric heated grips or electric heated gloves - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 19 (permalink) Old 02-12-2007, 10:39 PM Thread Starter
Never having used electric heated grips or electric heated gloves, I am asking for opinions from those that have. I would appreciate any advise or pros and cons of each.
2005 Shadow Sabre
Sabre4 is offline
post #2 of 19 (permalink) Old 02-12-2007, 11:08 PM
Sparc's Hotchick's Avatar
I have heated gloves. The reason I chose gloves over grips is because the grips only warm the inside of your hand, which is not the part that really needs it. The gloves heat the back of your hand and each finger. However, the gloves are definately more expensive and you'll have to run a wiring harness through your jacket if you get gloves only (if you get a jacket, the gloves plug into the sleeves of the jacket). I have both the gloves and the jacket liner from Gerbing and have been extremely happy with them. I do recommend that you get an adjustable controller, as they get hot and the controller allows you to dial-a-warmth.
All that said, I know several people who have heated grips and they are happy with the grips, so I think it comes down to personal preference.
Sparc's Hotchick is offline
post #3 of 19 (permalink) Old 02-12-2007, 11:44 PM
I hear (though have no direct experience) that heated gloves are more comfortable warmth wise. As the Hotchick said, they warm you where you need it. On the downside, you now have two or three (more) cables to connect when you suit up. So it can be a bit cumbersome. And if you misjudged the weather and left them at home . . . well then they are less comfortable than grip heaters.
Heated grips, while not providing as much comfortable heat (warming just the parts of the hand that contact the grip) offer convenience. They are always there for you when you need it (winter or summer) and nothing extra to deal with when you suit up.
Sparc
Faster than my Shadow
Sparc is offline
post #4 of 19 (permalink) Old 02-13-2007, 04:49 AM
Heat
I went for heated grips and hand guards.
Heated grips alone are not good enough in cold weather cause back of hand freezes (knucles), So I added the hand guards, now back of hand do not freeze and heat from handle is more difuse and stays around hand due to hand guards. I am stisfied with this set-up
heated grips goes from 35$ to 300$, hand guards are 100$ a pair. Heated gloves goes from 170$ to 300$
Bwadife is offline
post #5 of 19 (permalink) Old 02-13-2007, 06:20 AM
denisep's Avatar
I have the Honda heated grips. I wanted something that would serve in case I was caught out and temperature dropped. You may not have those gloves with you--but the grips can always be turned on. The grips are also very super nice when it's between 40-55 and you just want to knock that chill off. My husband rode my bike home yesterday with me on the back-- first time he'd tried the heated grips and he was shocked at how nice they made the ride.
I ride with fleece undergloves, lined leather gauntlet gloves over-top and am comfortable with the heated grips unless the temp drops below 20 or below 25 with lots of wind. Most of us do not ride below those temps anyway.
The tips of my fingers still get cold when it's below freezing, however the grips do a good job of keeping most of my hands pretty comfortable. The ideal situation as we've read on here before, is to use both, but if you can't do both-- then you have to pick what's best for you.
2008 Kawasaki ZZR600 in Candy Plasma Blue
"I would rather take an ass whippin' as to ride every winter day in a cage. " Tnshadowrider
denisep is offline
post #6 of 19 (permalink) Old 02-13-2007, 08:18 AM
I have to agree with Sparcs Hotchick about the heated grip/gloves idea, however - I haven't had any problems with the back of my hands getting cold with my heated grips. I can now wear lighter gloves instead of those gaunlet style I used to wear.
And I figure with a lightbar and heated grips, adding heatd clothing would be pushing my charging system a bit too far. I guess to me it's better for me to have warm hands instead of just warming my body. If my hands are warm, the rest of me seems to be warm too. >PD<
PainterD is offline
post #7 of 19 (permalink) Old 02-13-2007, 08:21 AM
adlowe's Avatar
I've got Widder heated gloves; messing with the wiring can be a pain at times (when hurrying to get on the road) but they're well worth it. Since I tend to be too warm, I've often worn them without hooking up the wires and they did just fine for me down to about 35 degrees; with the wires I've used them to below 20 degrees and they worked just fine for me. (If I've got it right, Widders don't get nearly as warm as the Gerbings do -- why I would prefer the Widders.)
No experience with heated grips so I can't give a comparison.
Art's 1999 Shadow 1100 ACE (Ride bell by Dr. Bob's Patient)
adlowe is offline
post #8 of 19 (permalink) Old 02-13-2007, 10:11 AM
sanoke's Avatar
I have heated grips on all three of my bikes and they really work well for me. I found that a good pair of leather ski gloves that have a small amount of lining on the palms and a thick lining on the backs works really well. The thin lining on the palms lets the heat from the grips through and the thick lining on the back keeps it in. I also waterproof the backs of my gloves and that helps to keep the wind out of the gloves.
I can see where heated gloves would work really well too but it sure is nice to be able to reach down and dial up the heat if some cooler weather takes me by surprise no matter what gloves I'm wearing.
sanoke
If you don't have to be somewhere, you're never lost, you're just ridin around.
sanoke is offline
post #9 of 19 (permalink) Old 02-13-2007, 10:26 AM
Bigguy2x's Avatar
sanoke,
What type of heated grips do you use?
E. J.
2006 Vulcan 1600 Classic
I am 100% sure that 75% of what I say is 50% right, 25% of the time.
Bigguy2x is offline
post #10 of 19 (permalink) Old 02-13-2007, 10:37 AM
Aeromark99's Avatar
Ditto sanoke. Heated grips do, in fact warm the whole of your fingers - it just takes a little while for the warmth to transfer to the backside of your hand from a cold startup. With decent windproof gloves, heated grips keep me comfy down into the high teens at freeway speeds. My toes are usually my limiting factor of my comfort level in cold weather.
Did I offend anyone?
Aeromark99 is offline
Heated Gloves, Grips, or Overgrips AThom10731 General Bike Discussion 18 01-12-2013 10:20 PM
clear hand deflectors heated gloves, heated grips rockaloka General Bike Discussion 10 08-18-2009 03:59 PM
Product Review; Widder Electric Heated Gloves Buzz Carsu General Bike Discussion 1 11-12-2007 09:11 AM
heated gloves or grips? moparrh General Bike Discussion 16 10-13-2007 07:17 PM
Heated Grips and Kuryakyn ISO Grips blassoff General Bike Discussion 1 01-23-2007 11:11 AM
