GPS or wireless speedo - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 10 (permalink) Old 04-04-2017, 10:55 PM Thread Starter
I wanted to see if any of you fellow riders have replaced or use a gps or wireless speedo. I have a batwing on now and like all 1100 spirits you have to ditch the enormous speedometer to make it work. I wanted to replace it with something accurate and hopefully stylish. Any ideas are welcomed and feel free to post pics of your setup.
thanks
crash33 is offline
post #2 of 10 (permalink) Old 04-04-2017, 11:22 PM
Coop's Avatar
I use a GPS all the time for speed, mainly because it is more in my line of sight.
No clue on the exact issue you are having, but I am running a Garmin LM 50, auto GPS on home made bracket. If it rains I put a Ziploc over it, secure with rubber band.
Ride Bell By The Bride and Canyon
Retired bell by Old Dad
2 time BOTM winner
06 VTX Glide & 05 ST1300
Coop is online now
post #3 of 10 (permalink) Old 04-05-2017, 07:09 AM
sidejam's Avatar
Just out of curiosity, don't you need to keep the factory speedometer or some type of speedometer that has an odometer as well? Something worth considering or not important?
sidejam is offline
post #4 of 10 (permalink) Old 04-05-2017, 12:24 PM
That is actually a good point. You can't sell a vehicle in a lot of states without knowing the actual miles on it.
jpr1968 is offline
post #5 of 10 (permalink) Old 04-05-2017, 12:34 PM
i2iweb's Avatar
I just switched out my speedometer on my 1994 vt1100c 2 weeks ago with an Acewell 4553cp that I got for a great price on Ebay. I was originally going to use a gps for speed pickup but decided to stick with the wired one from Acewell and it's worked out perfectly because I got it setup to where it matches the gps on my phone perfectly. I just took the time to set everything up correctly which wasn't so hard and it's well hidden. The speed sensor is on my back wheel and I made a simple bracket for it using a threaded rod and a drilled hole through the rear brake brace.
ID:	203801   Click image for larger version
ID:	203817   Click image for larger version
1994 VT1100c
i2iweb is offline
post #6 of 10 (permalink) Old 04-05-2017, 02:19 PM Thread Starter
Ok so I haven't ridden bike that much since I took off the speedometer so the milage isn't off that much maybe 200-300miles. I still have the original speedometer so that's not a problem. I am looking for options on a gauge rather than a screen. I don't mind wiring something up as long as it is accurate. I was thinking GPS but there aren't many options that are affordable, I'd like to spend less than $200 if possible. I'd like to make it look factory or at least fit well so that is why I'm asking for opinions and pics to help.
Thanks for the ideas and pics so far.
crash33 is offline
post #7 of 10 (permalink) Old 04-06-2017, 07:42 PM
GB6049's Avatar
Model: Shadow Spirit VT750 DC
Year: 2006
Using a GPS speedo / tach combo from SpeedHut. Works great. High beam, turn and neutral indicator.
GB6049 is offline
post #8 of 10 (permalink) Old 04-07-2017, 01:19 PM Thread Starter
I like speedhut but they are a little pricy GB6049, I might consider it though. Question did you put spacers on your risers to make it fit? It looks really nice and I dig the silver wire cover to make it look factory.
crash33 is offline
post #9 of 10 (permalink) Old 04-07-2017, 09:34 PM
GB6049's Avatar
Year: 2006
I added riser extensions years before I did the speedo. I designed the cup had it welded and then I polished it. Used a P-clamp to attach it to the bars.
2014 Mods by Greg Bishop | Photobucket
GB6049 is offline
post #10 of 10 (permalink) Old 04-07-2017, 09:51 PM
sidejam's Avatar
You think the gauges from SpeedHut are pricey? I thought they were very affordable. If budget wasn't an option, I'd be looking at gauges from here:
https://motogadget.com/en/
sidejam is offline
wow,,Valve Cap Wireless Tire Pressure Checker SHADOW 1100T General Bike Discussion 5 09-29-2009 02:39 PM
