1993 Shadow VT1100 build thread - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 17 (permalink) Old 08-05-2018, 02:50 PM Thread Starter
MtnDweller's Avatar
Model: VT1100C
Year: 1993
I figured I’d start a build thread to document the process. Not real sure how deep I’ll need to go or the extent of the build. These kind of projects seem to take on a life of their own as you move forward
Here’s what I have to start with.
Asking price was $400. I gave $300.
I figure at 300 bucks it’s worth a go. I already got her to fire but she wouldn’t stay running. But since she did fire off it was a good sign.
I also have the seats that are not torn and all the covers.
It’s a good start to a fun build.
MODERATOR:
If this is in the wrong place or not allowed I apologize.
ID:	256508   Click image for larger version
ID:	256510   Click image for larger version
ID:	256512   Click image for larger version
ID:	256514   Click image for larger version
1993 Shadow VT1100C
Mods forthcoming
MtnDweller is offline
post #2 of 17 (permalink) Old 08-05-2018, 03:37 PM Thread Starter
MtnDweller's Avatar
Model: VT1100C
Year: 1993
So 1st problem is the drag bar. I ordered a buckhorn bar for it.
2. problems with the drag bar.
1....it hits the tank on full turn. Yep I could by riser extensions but I’d rather sit back vs forward in the seat.
And the controls don’t sit right on that bar due to the original bar was originally a tall bent bar that I’ve often called “wheelbarrow”.
Also The throttle grip is broken.
I need to find one that I like. Post your grips. Also the choke Seems to be part of that construction. It looks like there’s a sleeve that runs along side the throttle that allows me to choke It from the grip. I’m not sure because it was in a box. Any insight on this one? If I can’t figure this out I will run a manual choke just under the tank somewhere.
1993 Shadow VT1100C
Mods forthcoming
post #3 of 17 (permalink) Old 08-05-2018, 08:54 PM
Leathel's Avatar
I dont have my 1100 anymore so cant take pics of it.....but I think a lot of the images are still on my old thread so it may have something to help?
https://www.hondashadow.net/forum/53...ne-so-far.html
They are a great bike...... only sold mine as I needed the coin to get my Valkyrie
My Bike before and after , Any day spent on the bike is a good day
VT1100C Shadow (1993)
VT750 Aero
TRX300 (Hunting Quad)
DRZ400E (my dirt bike)
For the kids to use
XR250
Rm80/Honda125 (1972 TL engine )
GN250
Leathel is offline
post #4 of 17 (permalink) Old 08-05-2018, 10:04 PM
Wildman_93's Avatar
Model: VT1100C Shadow Bagger
Year: 1993
Regarding the choke / throttle grip...
If you have the stock controls, the throttle is a pretty standard 2-cable type (push-pull).
The choke is located on the left side grip housing.
I may have some take-off parts for your build, left over from my own build. Let me know what you need.
Here are some pics. Not sure why they're rotated 90 degrees.
ID:	256528   Click image for larger version
Shadow Bagger
1993 VT1100C Shadow Bagger
2013 Victory Cross Country Tour
Wildman_93 is offline
post #5 of 17 (permalink) Old 08-06-2018, 09:52 AM Thread Starter
MtnDweller's Avatar
Model: VT1100C
Year: 1993
Thanks guys.
That helps quite a bit.
1993 Shadow VT1100C
Mods forthcoming
post #6 of 17 (permalink) Old 08-07-2018, 01:02 PM Thread Starter
MtnDweller's Avatar
Model: VT1100C
Year: 1993
I had to order a new throttle and controls off e-bay since the old cables were worn, the screws were missing, the throttle tube was broken etc.... I just decided that by the time I bought new grips, a new cable etc. I would be ahead of the game just finding a new assembly for 40 bucks. So now I wait for the stuff to come in. I think tonight I will start to remove the carbs for a good cleaning and get new plugs in her while waiting. Hopefully I can get everything by the weekend and get all of it out together and have her running by Sunday night. That's the plan.....Bwahhaaahhaaaa
1993 Shadow VT1100C
Mods forthcoming
post #7 of 17 (permalink) Old 08-08-2018, 08:45 PM Thread Starter
MtnDweller's Avatar
Model: VT1100C
Year: 1993
Ran into a little snag that I’m hoping someone might know the answer to.
In the attached diagram I put an arrow at a t-fitting that seems to be missing on the vacuum system. Is there anything special about it? Is there check valves etc in it? Or can I just go get a t-fitting from ace hardware and throw it on? Looks like the PO took it off for some reason.
Thanks for any help.
1993 Shadow VT1100C
Mods forthcoming
post #8 of 17 (permalink) Old 08-08-2018, 10:01 PM
Model: 2007 Shadow 600
prolly generic.
2007 Honda Shadow 600
RONW is offline
post #9 of 17 (permalink) Old 08-08-2018, 10:04 PM Thread Starter
MtnDweller's Avatar
Model: VT1100C
Year: 1993
Originally Posted by RONW View Post
prolly generic.
That’s what I’m thinking too.
1993 Shadow VT1100C
Mods forthcoming
post #10 of 17 (permalink) Old 08-09-2018, 12:17 AM
Leathel's Avatar
Yes any tee will do
VT750 Aero
For the kids to use
XR250
GN250
Leathel is offline
1993 VLX600 Bobber Build Thread zcoppola General Bike Discussion 2 08-24-2015 09:31 PM
My 1993 Honda Shadow VT1100 3rd thread 93 SHADOW Member Introductions 0 01-08-2013 02:34 AM
My 1993 Honda Shadow VT1100 2nd thread 93 SHADOW Member Introductions 0 01-08-2013 02:27 AM
1993 VT1100 Shadow, only one (1) cylinder is firing itmandk Technical Discussion 1 06-29-2009 07:54 AM
Purchased Used Honda Shadow VT1100 V-Twin 1993 60000 Kms kenmathur Technical Discussion 1 05-12-2008 08:56 PM
