Can you tell the difference in sound on a VT Honda or a HD - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 32 (permalink) Old 04-12-2019, 05:47 AM Thread Starter
Hi!
Can you tell the difference in sound on a VT Honda or a Harley D. (both bikes with straight pipes) when you hear a bike approaching you from a distance?
I did not guess right once when I guessed... I guessed on a old HD but the bike that came was a VT1100.. =)
cromwell74 is offline
post #2 of 32 (permalink) Old 04-12-2019, 06:23 AM
Steve C's Avatar
Model: Non Shadow 1982 Honda GL500I SilverWing Interstate, two cyl. transversive "twisted"twin
Year: 1996 VT1100C2 ACE Shadow
HD sued Honda over this and lost.https://www.google.com/url?sa=t&rct=...UmFKhF-IHYwS7x.
1996 VT1100C2 ACE Shadow,1982 Honda GL500I SilverWing,1980 AMF Roadmaster w/Minarelli V1 moped.."It's the journey not the destination" Ravens Roost Overlook milepost 10 Blue Ridge Parkway,Virginia
Steve C is offline
post #3 of 32 (permalink) Old 04-12-2019, 06:58 AM
Super Moderator
Phil's Avatar
Model: 750 ACE Dlx
Year: 1998
You probably couldn't tell which one was the Harley because they were both moving and from a distance. Up close you should be able to tell them apart.
Phil
1998 VT-750 ACE Deluxe
Sterling Heights, Michigan
Phil is offline
post #4 of 32 (permalink) Old 04-12-2019, 07:23 AM Thread Starter
Phil
At that time there was only one bike coming and that was the VT1100.... =)
post #5 of 32 (permalink) Old 04-12-2019, 08:05 AM
tc862011's Avatar
Isn’t the vt1100 a single pin motor like Harley’s that’s why it makes the Harley “potato potato” sound
1986 honda shadow vt700c - roxy
tc862011 is offline
post #6 of 32 (permalink) Old 04-12-2019, 08:56 AM
Super Moderator
Phil's Avatar
Model: 750 ACE Dlx
Year: 1998
Okay, got it....
I've heard some nice sounding exhaust tones from Honda V-twins (my 750ACE being one of them.)
I've never owned a Harley but have friends that do, the reason I mentioned hearing them "Up Close" is because Harley engines have more of a mechanical sound. Harley's use rocker arms actuated by push rods riding on a cam to open the valves, whereas Honda V-twins have overhead cams which eliminates the push rod and the rocker arm.
Phil
Phil is offline
post #7 of 32 (permalink) Old 04-12-2019, 10:15 AM Thread Starter
So my VT800 can´t get that "potato potato" sound then?
post #8 of 32 (permalink) Old 04-12-2019, 10:19 AM
tc862011's Avatar
The 1100 I believe was the only one with a single pin crank, meaning the cylinders move up and down at the same time altho each one is in a different cycle, ones exhaust while the other is intake, the 800,750, and 650 are all dual pin cranks meaning the pistons move opposite . One is moving up as the other moves down. Hard to get a dual pin to sound like a Harley because of this unless you lower the idle to much and then you are starving the top end of oil at idle
tc862011 is offline
post #9 of 32 (permalink) Old 04-12-2019, 10:20 AM
tc862011's Avatar
You get more power and smoother motor out of a dual pin motor, compared to a single pin motor of the same size
tc862011 is offline
post #10 of 32 (permalink) Old 04-12-2019, 10:22 AM
Kris Carr's Avatar
Model: VT500C
Year: 1984
I never thought the "potato potato" sounded good at idle. Sounds out of tune like uts struggling to stay alive. They sound ok cruising but at a stop light they make me gringe
Kris Carr is offline
Difference in sound/timing - OLD vs NEW? Please Clarify! Daniel Soriente Technical Discussion 2 05-15-2017 07:49 PM
Crash bars/highway bars How to tell the difference? KOKO07 Member Introductions 7 05-05-2012 09:58 PM
Difference in pipe sound between 600cc and 1100cc rkneeshaw Technical Discussion 0 06-26-2008 10:54 PM
How do I tell the difference in size? Onin General Bike Discussion 5 06-10-2008 05:11 PM
