87 Magna/86 VT1100 project done - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 14 (permalink) Old 06-12-2019, 06:36 AM Thread Starter
Model: VF700 Magna
Year: 1987
https://www.hondashadow.net/forum/at...1&d=1560335690
ID:	263296   Click image for larger version
ID:	263298   Click image for larger version
If I cant fix it, I will muck it up so nobody can
justed is offline
post #2 of 14 (permalink) Old 06-12-2019, 07:51 AM
flames9's Avatar
Sharp
Bikes:
1978 Yamaya MX80
1970s Homemade bike, like 50cc..
1981 Yamaha XT 200 Enduro
1986 Yamaha Radian 600
2004 Honda Shadow Aero 750
2017 Honda Africa Twin DCT
flames9 is online now
post #3 of 14 (permalink) Old 06-12-2019, 08:30 AM
Oh YEAH!!!
That`s a Beauty!!!
What with my 96 - V4 sitting and my current rider in limbo with insurance,
I`m strongly thinking on getting the MAGNA Road ready...
I Love it when a plan comes together...
Therapy is painful, BUT I`m progressing,
D
`98 VT750 A.C.E.
ABATE member 40+yrs.
www.ABATEGA.org
(DC District 13)
www.mrf.org
www.MSF-USA.org
http://www.ama-cycle.org/
Enjoying Life,D
"Captain D" is offline
post #4 of 14 (permalink) Old 06-12-2019, 01:59 PM
Great job. it really looks good
jpr1968 is offline
post #5 of 14 (permalink) Old 06-12-2019, 02:05 PM
Year: 2000
Am I reading the title wrong? Magna's didnt use VT1100 motors, and they weren't made in 87.
Chuck_Michigan is offline
post #6 of 14 (permalink) Old 06-12-2019, 03:50 PM Thread Starter
Model: VF700 Magna
Year: 1987
Partly correct in that Magnas didnt use VT motors, Magnas use the V4. My donor bike was an 86 VT1100, front clip. MY bike is an 87 VF700 Magna. Magnas were made from 1982 and into the 90s. For the VT1100, introduction year was 1985, and only the 85-86 1100 had dual front brakes.
justed is offline
post #7 of 14 (permalink) Old 06-12-2019, 04:31 PM
Turned out great looking, like it was meant to be.
What did you have to do to make it come together?
CSRoad is offline
post #8 of 14 (permalink) Old 06-13-2019, 06:47 AM Thread Starter
Model: VF700 Magna
Year: 1987
Because I swapped the entire VT1100 front clip, it made the project easier. But, still hurdles to jump to keep it looking OEM and not hacked together.
Bought a Magna gauge harness and wired it to the VT gauge cluster - time consuming pain in the ass - 85 to 90% of the VT and VF wiring has the same color code and function, but location and routing change. The VT risers put the handle bars against the tank when the bars were at full left or right when parked (risers and triple clamps together moved the bars too close to the tank), so I picked up a set of risers from an 88 or 89 VT1100 which raised the bars to a perfect height. Triple clamp steering stem/lower bridge is a little different than the Magna - shorter because of how its mounted in the lower triple. I had to cut the stem, separate the 2 halves by 20mm, insert a piece of solid bar stock that had to be machined to match the ID of the stem, had it welded together - that raised the threaded part of the stem 20mm, which matched the height of the Magna so I could bolt it all together.
Things to do - paint the front rim to match the Magna silver/gray - I thought I would like the black after it was all bolted together but I dont. Need to paint the fender to match the rest of the bike. Once Im 100% sure Im done, will put the lower plastics back on (lower plastics prevent me from putting bike on motorcycle lift).
My Magnas brakes worked fine, this project was all about the dual disk look. The 85-86 VT1100 was the only thing I found that matched the Magna fork and wheel design - 5 spoke rim with center axle.
There you have it, my story
justed is offline
post #9 of 14 (permalink) Old 06-13-2019, 11:25 AM
Thanks for the break down on the procedure you followed and the hurdles you encountered.
I'm sure it will be of value to others.
CSRoad is offline
post #10 of 14 (permalink) Old 06-13-2019, 11:29 AM
blupupher's Avatar
Model: VT1100C
Year: 1994
Interesting look. Just looking at the pics, I could tell something was different, but not sure what it was. Seemed like the rake had been change or something.
Front end sits a little higher also?
How did it change handeling? I know the Magna had a little sportier handling than a Shadow.
1994 VT1100C
Starfire 185/65/15 rear tire (Darkside)
Perilli MT66 Route 110/90/19 front tire
Progressive 430HD Rear Shocks
Mustang Seat
National Cycle Windscreen
blupupher is offline
