Final drive oil change ? - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 24 (permalink) Old 03-31-2011, 03:03 PM Thread Starter
Hi all! Wondering if anyone can answer a question for me. I'm going to change the final drive oil on my VT1100 Shadow. The manual calls for 90w Hypoid Gear oil. My local Honda dealer sold me Honda HP Trans Oil SAE 80w/85w to use. Will this be ok to use? Thanks for the help?
Nickbomb is offline
post #2 of 24 (permalink) Old 03-31-2011, 03:09 PM
im pretty sure my manual (86 vt500c) calls for SAE 80w-90w so i would say its ok. im sure someone with your exact model will chime in
1986 Honda Shadow VT500c
reno1051 is offline
post #3 of 24 (permalink) Old 03-31-2011, 03:09 PM
Which Manual?
I think I used 80/85 when I changed mine.
Just be careful when you tighten that plug. Don't torque it, just snug it to compress the "O" ring or you'll be running to the dealer to buy a new one.
Your bike should be on the side stand when you fill or check it. The fluid level should come up level with the bottom of the fill plug hole with the bike on the side stand..
Don't worry if you see some oil weeping out of the chrome vent on top as you ride. It's normal when the oil expands. If it wasn't able to do that it would explode.
'98 Shadow 1100 ACE
Notorious is offline
post #4 of 24 (permalink) Old 03-31-2011, 09:27 PM
tubes_rock's Avatar
Standard 80W-90 will work just perfectly! It is essentially 90W oil when it heats up, but flows like 80 weight when cold to gets the gears lubed quicker. perfect for your bike!
And welcome to the nut-house!
--Justin
Currently Running Stable:
2010 Honda NT700V
1986 Shadow 700
1987 Honda Rebel 450
1973 Honda Mini Trail 50
tubes_rock is offline
post #5 of 24 (permalink) Old 03-31-2011, 09:30 PM
Welcome to the horde.
And as others have already stated, the gear oil is fine.
Martin
Kingshead is offline
post #6 of 24 (permalink) Old 03-31-2011, 11:28 PM
Talking rear diff fluid
I just changed mine I am using a clymer manual It states to have the bike off the side stand and straight up and down to check and fill the rear diff. I did torque the fill plug and drain plug with a new gasket on the drain plug, no leaks I need to double check the manual. Also a foot note the clymers manual says to get NEW caliper mounting bolts to reinstall caliper I have never heard of this I just added a drop of locktite and torqued them.
coloradoklr is offline
post #7 of 24 (permalink) Old 04-01-2011, 10:19 AM
h13man's Avatar
Not knowing your bike model/make this is quoted from a Honda manual.
Honda Manual Procedure.
FINAL DRIVE OIL
LEVEL CHECK
Place motorcycle on its side stand on a level surface.
Remove oil filler cap.
Check that the oil is up to the loweredge of the oil filler hole.
Pour recommended oil thru the oil filler hole until it reaches the lower edge of the hole.
4.4 ounces recommended for 1997 & up 1100 Spirit & 1998 & up Ace Tourer. 9 ft.lbs. of torque for the filler cap. (5.1 ounces if a complete teardown is done.)
Not doing it this way causes overfill and d**n mess. How do I know? I had a Clymers and done it as stated. Supposedly a overfill not corrected can cause damage. I assume if the air space in the hub assembly is lessened by excess fluid it will probably cause the oil to "froth" thus not lubricating properly. A situation that more isn't better. It was explained to us a couple years ago by "Litin" which is somewhat a respected mechanical "guru" on the forum.
71' CL 100 "Lil' Sista"
99' Valkyrie "Adele"
05' 1600 Vulcan "Ludabelle"
Ride Bell by "Yoman"
h13man is offline
post #8 of 24 (permalink) Old 04-01-2011, 10:58 AM
im like 99% sure my manual says to do drain it on the side stand and fill it on the center stand. that is what i did and i had no excess leakeage from the relief after riding. of course this is for bikes that still have the center stand. the casing would be adjusted for bikes with only side stands to account for the additional oil necessary. remeber, too little is bad but too much will just leak out and provide the right amount. messy of course but its a fool-proof application
reno1051 is offline
post #9 of 24 (permalink) Old 04-01-2011, 11:22 AM
I checked with my Honda dealer. They say it is an error in the Clymer manual. I'll be picking up a genuine Honda service manual instead. (2006 Shadow Sabre)
marcham is offline
post #10 of 24 (permalink) Old 04-01-2011, 11:38 AM
The shop manual in the sticky and my original owners manual say to place bike on the Center stand. This is for a VT500C. Can any VT500C peeps chime in if they do side stand or center stand please.
Crash
1984 VT500C Shadow Ox Blood Red
CrashOverride is offline
Oil, Filter & Final Drive Oil Change @ 600 Miles NJSPIRIT Technical Discussion 10 06-18-2019 11:07 PM
Final Drive oil Change journey Technical Discussion 14 08-20-2012 08:33 PM
Final drive oil change Mark_ Technical Discussion 8 05-24-2012 12:14 PM
final drive oil change Cobra49 Technical Discussion 6 05-12-2008 07:52 AM
Final drive gear oil change timothye1 Technical Discussion 9 04-07-2008 01:17 PM
