93 vt1100 choke cable - oem vs motion pro - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 6 (permalink) Old 11-03-2011, 10:30 AM Thread Starter
So, I need a new choke cable for my 93 vt1100. Its the one thats on the left hand switch and splits into two under the tank. The OEM one is like 55 and the Motion pro is about 10 cheaper (from what I found).
Now, I've seen it both ways...one the OEM is better, another the Motion is better.
Anyone have any advice on this?
1970 Honda 50 Mini Trail - gone, but not forgotten
1978 Honda 50 Z
1975 Suzuki RV 125
1993 Honda VT 1100
1982 Kawasaki 550 LTD
1968 BSA B44 - sold...
1980 Kawasaki 750 LTD - sold to get the shadow
1973 Honda CB 500 - sold
apbling is offline
post #2 of 6 (permalink) Old 11-03-2011, 11:17 AM
-AJ
-AJ's Avatar
Motion Pro is a good company. you shouldn't have a problem with them. Motion Pro is what we recommend at the shop for all our cables.
I started out with nothin'... and i still got most of it left.
2006 Honda VTX-1300R
Memphis Shades Batwing, Stock "C" Model Pipes, Mustang Seat, Mustang Fender Bib, National Cycle Hard Bags,
Lindby Multibar, Küryakyn Sound System, Küry ISO Grips, Show Chrome Grille Cover, Küry L.E.D Light Kit, Küry Triple Whammy,
Küry Constellation Light Bar, TTO Tach, Metzeler Tires, Chromed Wheels and much, much more.
-AJ is offline
post #3 of 6 (permalink) Old 11-03-2011, 02:13 PM
It's JUST a choke cable. Personally I'd get the cheaper one. Being that cheap MFG happens to be Motion Pro, even better. Now on the choke Valve components, I would go OEM, or at least Keihin.
93gc40 is offline
post #4 of 6 (permalink) Old 11-03-2011, 04:37 PM Thread Starter
Wasn't aware you could even get choke valve components. Why would you ever need them, unless your bike sat for quite some time and they got corroded beyond usability?
1978 Honda 50 Z
1975 Suzuki RV 125
1993 Honda VT 1100
apbling is offline
post #5 of 6 (permalink) Old 11-05-2011, 01:22 PM
Yea you can get them. My bike lives outside, no garage. And I ride in the rain. So even though it's under a cover it is exposed to moisture. Moisture and cables don't mix. Any way, IF I don't keep the cables well lubed and clean they rust and corrode. My cables are 10 years old. Gravity has a way of depositing water thet finds it's way inside a cable housing to the lowest point of the cable. On the choke cable that is the valve. It doesn't take very much water to disolve those littte springs.
93gc40 is offline
post #6 of 6 (permalink) Old 11-05-2011, 02:12 PM
I used Motion Pro on my 96 vt1100 with no problems. I found it on ebay and was cheaper than that. If I remember correctly it was about $35 with free shipping.
zappa is offline
87 vs 90 Ethanol Free vs 93 vs 89, my results... Zanshin General Bike Discussion 15 07-28-2014 10:29 PM
4th of July Sale! - Save 20-25% on K&N, EBC, Renthal and Motion Pro Motorcycle Products! MotoSport.com Motosport.com 0 06-24-2013 12:35 PM
choke cable broke! 93 1100 VT apbling Technical Discussion 3 10-22-2011 08:21 PM
Questions on using the Motion Pro Jumbo Chain Tool 08-0135 CJH Technical Discussion 0 08-02-2009 10:51 PM
