Switch cleaning 101 - Page 3 - Honda Shadow Forums : Shadow Motorcycle Forum
Closed Thread
post #21 of 29 (permalink) Old 09-29-2013, 06:14 AM
Nice Job
My bike it completely torn down waiting for a Tig Welder to come by and do crankcase repair this morning, fingers crossed.. I've been into electronics for years and there is a cleaner called PURETRONICS Electrical Cleaner and Lube, which is light years above cheaper brands ..It's all I use ... Lasts Forever .. All these LED LIGHT Stuff are new to me altho I do run LED RUNNING LIGHTS & STOP LIGHTS inside the turn signals... but they've come out with alot more stuff I am interested in but havent had time to check out. all this bike maint is cutting into my guitar playing time also .... Thanks for the tip . am gonna do an ALL OVER THE BIKE when putting back together as it's coming up on 10 years .. ( 2004 1100 Sabre)
68Dontbelate is offline
post #22 of 29 (permalink) Old 09-29-2013, 08:29 PM
White Dog's Avatar
Anybody ever taken a dimmer switch apart to clean? How did you get it apart?
White Dog is offline
post #23 of 29 (permalink) Old 12-08-2013, 06:25 PM
The photo from the OP is priceless. Thank you so much for this write up.
Karankawa is offline
post #24 of 29 (permalink) Old 12-08-2013, 06:31 PM
I gotta clean and lube my "Kill Switch" one day in the near future...
The dimmer is the same rocker type, on mine...
`98 VT750 A.C.E.
ABATE member 40+yrs.
www.ABATEGA.org
(DC District 13)
www.mrf.org
www.MSF-USA.org
http://www.ama-cycle.org/
Enjoying Life,D
"Captain D" is online now
post #25 of 29 (permalink) Old 12-20-2013, 01:44 AM
02 Spirit's Avatar
Thanks for the writeup.. Did mine today and works like a dream now.
02 Spirit is offline
post #26 of 29 (permalink) Old 12-20-2013, 01:58 PM
Flying Greg's Avatar
I was having blinker troubles on my '89 VT 1100 and cleaned the switch a number of times. Seemed to happen more when the temps got down under 50. I read on this Forum about the blinker relay being a mechanical switch of some kind that operated on heat which would lead to failure during cooler times. I finally bought a solid state electronic flasher at www.superbrightleds.com that cost all of 8.95 plus 2.00 shipping that simply plugged in where the old mechanical unit was, and since then, not a bit of trouble. The unit I bought is the LF1-S-Flat Universal Flasher. the old one had three wires, but the new only two and it simply plugs right into the existing wire harness. Easy squeezy.
...Nothing in moderation...
Greg
Flying Greg is offline
post #27 of 29 (permalink) Old 12-21-2013, 07:07 AM
brianjenn82's Avatar
Thanks for the write-up on this. I was not having any issues, other than turn signal seemed a little gummy. I tore them all apart this morning and used electronic contact cleaner, thin dielectric grease on contact, and greased lightly where everything slides. Difference in turn signal switch is like night and day. It actually has a click to it instead of mush! haha!
2007 HONDA SHADOW 1100 SABRE
"Be who you are and say what you feel, because those who mind don't matter, and those who matter don't mind."
brianjenn82 is offline
post #28 of 29 (permalink) Old 02-17-2014, 06:35 PM
From my understanding, I need electrical contact cleaner along with dielectric grease? And I user it to clean the guide and pivot points? Great write up by the way!
jcpryor3 is offline
post #29 of 29 (permalink) Old 02-20-2014, 10:19 PM
Can someone confirm my previous post please?
jcpryor3 is offline
Closed Thread
Carb Cleaning 101 NorTex Technical Discussion 6 08-21-2015 06:04 PM
Clening, cleaning and more cleaning! aluminum!!! Maraxion Technical Discussion 17 08-06-2008 12:23 PM
For you newbies - Anticipation 101 sanoke General Bike Discussion 10 05-24-2007 09:59 AM
VLX Newbie - 101 Equis454 Technical Discussion 6 04-09-2007 08:48 PM
How to plan a group ride 101 ashadowrider General Bike Discussion 12 04-06-2007 08:59 AM
