Replacing Front Turn Indicator Stems - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 12 (permalink) Old 08-24-2012, 09:39 AM Thread Starter
The rubber stems on my 1985 Honda Shadow VT500 are cracked. I've taped them up but it's getting worse and the indicators are drooping. I've found replacement stems on ebay for a reasonable price but, before I buy, I want to make sure that replacing them is as easy as it seems. It's an old bike. Am I looking for trouble if I unscrew the stems? Is it as simple as just removing the one bolt that seems to hold it in place against the forks?
Thanks.
...Jake
j_colman is offline
post #2 of 12 (permalink) Old 08-24-2012, 11:19 AM
Should be 1 bolt holding them to the forks and 1 inside the stem holding the stem to the clamp and light housing
93gc40 is offline
post #3 of 12 (permalink) Old 08-24-2012, 03:02 PM
Earthling789's Avatar
Yes, it is that easy...
Remove the headlight and disconnect the three wires for each front signal (one set is light-blue/light-blue with white stripe/ green... the other is the same, but wire colors are orange instead of light-blue)
Unbolt the stems from the mount (not so easy to reach one on left side), then remove entire assembly with wiring.
Unscrew single screw holding lamp housing to stem, and pull wiring through old stem.
Now, if you bought cheap, aftermarket stems... the opening down the middle or end of the stem will be too small to push all three wires through at once... a trick I used is to tie a piece of fishing line to each of the bullet connectors on the wiring. Drop the three pieces of fishing line through the stems, then carefully feed one wire at a time through the hole, using the fishing line as a "tow-rope".
Once you get the wire through the stems... remove the fishing line from the wiring connectors and reverse the process to re-assemble.
Current -
2002 VT1100C2 Sabre
1985 VT700C Shadow (two, one is project-bike)
1999 CB750 NightHawk (oldest son's)
1998 VN750 Vulcan (youngest son's)
"The Hardest Part About a Zombie Apocalypse, Will Be Pretending I'm Not Excited"
Earthling789 is offline
post #4 of 12 (permalink) Old 08-24-2012, 03:31 PM Thread Starter
The wiring for the turn signals goes through the headlamp assembly? I have to remove the headlamp in order to replace the stems?
If I'm already taking the stems apart, is there any point to changing/upgradiung my turn signals in anyway? One of the housings is cracked but still usable. I'm wondering if there is any point in changing anything.
j_colman is offline
post #5 of 12 (permalink) Old 08-24-2012, 05:08 PM
Model: 2007 Shadow 600
for $9.95 ($8.90 shipping)here on Ebay, it's not a major expense (Taiwan). OEM is $20 +shipping. *Dunno whether the seller's pic below depicts the actual item.*
2007 Honda Shadow 600
RONW is offline
post #6 of 12 (permalink) Old 08-25-2012, 09:27 AM
All the wiring connections for the turn signals connect to the harnesses located behind the headlamp assembly... You don't have to remove the ENTIRE headlamp bucket from the mount... only the lens and reflector assembly....Remove the two screws which hold the headlamp assembly to the housing, twist, and the headlamp assembly pops right off. Trace the turn signal wiring from the stems to the mass of wires behind the headlight, and you'll find the orange and light-blue wires I mentioned.
As for replacing the turn signal housings... probably a good idea if either of them are cracked or scratched up. OEM are kind of expensive (~$45 each), but there are aftermarkets from BikeMaster and K&L. Both are much cheaper ($15-20 each), and work fine...
I installed K&L on mine. Both sides replaced with stems for <$20 each side. The reflectors didn't have the DOT markings, but who cares... , and the run/ground wiring was reversed from the instructions (which created a headache when installing them - see: https://www.hondashadow.net/forum/72-...signals-2.html).
Current -
2002 VT1100C2 Sabre
post #7 of 12 (permalink) Old 06-26-2016, 02:59 PM
rear turn signal stems/stays
This question goes along with this thread. Mine is the rear turn signal stems. Would you recommend the ones on Ebay for Rear Turn Signal Indicator Stem Stay Honda VT1100C VT 1100 C Shadow 85 86 Pair | eBay
ship from Taiwan or the OEM off of www.Bikebandit.com
Also does changing the back stems/stays seem as simple as the front does?
rebpooh is offline
post #8 of 12 (permalink) Old 06-26-2016, 05:42 PM
Steve C's Avatar
Model: Non Shadow 1982 Honda GL500I SilverWing Interstate, two cyl. transversive "twisted"twin
Year: 1996 VT1100C2 ACE Shadow
here's a OEM parts diagram plus part numbers, some are no longer available.Honda Motorcycle Parts 1985 VT500C A TURN SIGNAL Diagram
1996 VT1100C2 ACE Shadow,1982 Honda GL500I SilverWing,1980 AMF Roadmaster w/Minarelli V1 moped.."It's the journey not the destination" Ravens Roost Overlook milepost 10 Blue Ridge Parkway,Virginia
Steve C is offline
post #9 of 12 (permalink) Old 06-26-2016, 06:47 PM
The stems are generic front and back, actually for those year shadows. You do have to fish the wires through the stem though. Sometimes just pushing the wires through does it. Otherwise fish (pull) the wires one by one. Ditto, one by one, for gettin the wires outta the old stems.
RONW is offline
post #10 of 12 (permalink) Old 05-24-2019, 07:11 AM
Kryton's Avatar
Model: VT750C2F Spirit
Year: 2009
Are the rubber clamp-around stems are flexible enough spread open around the tube to remove without having to unclamp the tubes from the triple tree to slide off the end?
Kryton is offline
Rear turn signal stems 86 vt1100c jostran911 Technical Discussion 4 06-12-2013 12:12 PM
Question about turn signal stems. pandjlocke Technical Discussion 4 03-05-2013 01:52 PM
Turn Signal "Stems" yo_rocky Technical Discussion 6 07-13-2011 11:04 AM
