How-To: 4 Advance Timing and Clutch Spring Upgrade - Page 2 - Honda Shadow Forums : Shadow Motorcycle Forum
post #11 of 207 (permalink) Old 02-14-2013, 11:06 AM
SnoGhost13's Avatar
Re: How-To: 4 Advance Timing and Clutch Spring Upgrade
Is there a reason to replace the clutch springs if they are not bad?
Sent from my SPH-D710 using Motorcycle.com App
Joe
08 VT750C2 Shadow Spirit
SnoGhost13 is offline
post #12 of 207 (permalink) Old 02-14-2013, 11:10 AM Thread Starter
Aced It's Avatar
The aftermarkets like the EBC's are about 10% stiffer. They provide a bit more bite which is not a bad thing when performing the timing mod, and/or upgrading your clutch itself. Is it required? - No.
82 CB900C - CB Lingo for My Road
82 Magna - My Road is Magna-ficent!
91 VLX - My Road to Bob
03 ACE - My Road to Rod
"Keep the rubber side down, unless of course you have a rubber head!"
Aced It is offline
post #13 of 207 (permalink) Old 02-14-2013, 11:15 AM
GilaMinumBeer's Avatar
Is water wet?
GilaMinumBeer is offline
post #14 of 207 (permalink) Old 02-14-2013, 11:24 AM
big poppa pump's Avatar
Might sound dumb, but do I have to do any rejetting after doing this mod?
Thanks.
'04 ST1300A - BlueBeetle
'98 Honda Valkyrie F6C - BatValk
big poppa pump is offline
post #15 of 207 (permalink) Old 02-14-2013, 11:25 AM Thread Starter
Aced It's Avatar
Thanks.
No.
Aced It is offline
post #16 of 207 (permalink) Old 02-14-2013, 11:30 AM
Thanks. I know what I will be doing in 2 weeks....
post #17 of 207 (permalink) Old 02-14-2013, 01:16 PM
SnoGhost13's Avatar
Thanks! I'm only considering the timing mod because both side covers are seeping oil at the seal. Figure if I pull it apart to reseal I might as well mod the timing while I'm in there. Just wasn't sure if the springs were a preventive maintenance thing or another "mod".
Do the aftermarket springs change the feel of the clutch lever? Do a lot of in town riding and don't need extra cramping in my hand!
Joe
post #18 of 207 (permalink) Old 02-14-2013, 01:32 PM
Should give a more solid feedback through the entire sweep of the lever. Could be perceived as stiffer but should also prevent having to use the entire sweep between gears.
I might suggest if you are looking be wary of Barnett. I did my home work, verified part numbers, etc... and STILL got springs that are too large for my basket. Damned things are coil bound. Barnett has, of course, replaced the springs at their cost but I still have to crack the case open again to get the right springs inside the basket.
04' Honda Shadow Aero: Mutazu, Harley Davidson, Dynojet, Vance and Hines, Tiny Tach, Shindengen, Progressive, EBC, Colorite, Edelbrock, TJBC, Emgo, Optimax, and Metzeler.
post #19 of 207 (permalink) Old 02-14-2013, 02:15 PM
Is there any difference between Barnett & EBC clutch springs?
post #20 of 207 (permalink) Old 02-14-2013, 02:54 PM
Yes. Apparently EBC can get springs that match the bike they are spec'd for.
Otherwise, I dunno.
How much timing advance 95shadow1099 Technical Discussion 34 09-20-2012 02:46 PM
99 vlx timing advance bjg928 Technical Discussion 12 04-25-2010 09:56 PM
How to Advance our Timing ? rrounds Technical Discussion 3 01-22-2010 05:16 PM
Timing advance? txmetal Technical Discussion 12 01-31-2008 11:23 AM
Timing advance question morepower Technical Discussion 2 01-06-2007 07:07 PM
