How-To: 4 Advance Timing and Clutch Spring Upgrade - Page 21 - Honda Shadow Forums : Shadow Motorcycle Forum
post #201 of 206 (permalink) Old 01-29-2016, 04:04 PM
Well, I stopped by my local tractor supply and picked uP a 3/8s drive 5+ ft/lb TW made by jobsmart. Tested it out at work at on a 8mm bolt on a washing machine 9 ft/lbs and it gave me a definite click after so many turns.I'm thinking this one will do the job. Seems better quality than what I picked up at advanced, for only 10 moreally bucks. Can't wait to get home and try it out.
ToeCutter is offline
post #202 of 206 (permalink) Old 01-29-2016, 07:25 PM
ok....so.....major problem.....i torqued the bolt down TO SPEC. i can feel the clutch working (not running, i put the case on with a few boltsjust to see)...but....on the last bolt, the ******* stud broke off with the rest of the bolt stuck inside my ******* pressure plate......you have no idea how angry i am right now. someone please tell me this ******* wil run for a little bit with three bolts until i can get a new piece.....otherwise, this has been a great waste of time. man..if i didnt have bad luck i wouldnt have any luck at all. i also notices that my exhaust on the front cyl doesnt even have a gasket....not a big deal, cheap replacement, but jesus christ, man..
post #203 of 206 (permalink) Old 06-27-2016, 06:54 PM
I just did this Saturday. First, i want to thank aced it for doing such an awesome write up. Made the whole thing painless.
I love how grabby thenew springs are. I also the the extra throttle response. My opinion on the timing mod is if your going to tear it all apart just to advance the timing, its not really worth it. However, if your already in there to change the springs, its worth doing. On a side note, someone mentioned the tooth on the trigger wheel not lining up with the ipg. I had this happen, the toothed portion was not even close to the ipg, so i just gap checked it to the non toothed portion and it worked out fine. Im not sure what it measured as i just kept adding gauges to the stack until i had the right amount.
Abear2354 is offline
post #204 of 206 (permalink) Old 02-03-2017, 02:51 PM
Saddle Up's Avatar
Well done Aced It! Appreciate the detail.
Didn't anyone shim their springs? If so how thick?
I'd consider a new clutch cable only because my VLX is a 2003.
Stand up for something, or you'll fall for anything.
Saddle Up is offline
post #205 of 206 (permalink) Old 11-15-2017, 11:36 AM
Model: VT700
Year: 1985
1985 vt700?
Curious if this (EXCELLENT) writeup covers back to the 1985 model VT700?
astronutski is offline
post #206 of 206 (permalink) Old 11-15-2017, 12:40 PM
swifty2014's Avatar
Model: Vt750
Year: 1983
The older vt750 like ours have a spring washer instead of individual springs to replace for the clutch.
And the timing mod may not be needed since our older engines have a more aggressive advance built in at about 3500-4000 instead of the (original bike in the post) 2003 Ace 750 which is up to 5500 RPM, and 2 degrees less.
But if it has been tried I would like to see a post about the results from it. Knowledge is POWER !
ID:	234098   Click image for larger version
Name:	1983- 1985 vt750 ignition.PNG
ID:	234106   Click image for larger version
Name:	1985 750 ignition.PNG
ID:	234114   Click image for larger version
Name:	2003 750 ace ignition.PNG
1983 750 Shadow
From the past=
1951 Cushman scooter
1962 Honda 305 Dream
1965 Honda 305 Dream
1971 Honda 175 scrambler
swifty2014 is offline
How much timing advance 95shadow1099 Technical Discussion 34 09-20-2012 02:46 PM
99 vlx timing advance bjg928 Technical Discussion 12 04-25-2010 09:56 PM
How to Advance our Timing ? rrounds Technical Discussion 3 01-22-2010 05:16 PM
Timing advance? txmetal Technical Discussion 12 01-31-2008 11:23 AM
Timing advance question morepower Technical Discussion 2 01-06-2007 07:07 PM
