How-To: 4¯ Advance Timing and Clutch Spring Upgrade - Page 3 - Honda Shadow Forums : Shadow Motorcycle Forum
post #21 of 207 (permalink) Old 02-14-2013, 03:15 PM
bob_suruncle's Avatar
Nice write up Aced-it! very well done step by step.
Clutch springs are a good idea if you went to a 39 to 38t sprocket too
bob_suruncle is offline
post #22 of 207 (permalink) Old 02-14-2013, 04:01 PM
big poppa pump's Avatar
Originally Posted by GilaMinumBeer View Post
Yes. Apparently EBC can get springs that match the bike they are spec'd for.
Otherwise, I dunno.
Thanks. Now to place my order for the springs.
Mmmmmmm....I am wondering if I should order a replacement gasket for the crankcase....just in case.
'04 ST1300A - BlueBeetle
'98 Honda Valkyrie F6C - BatValk
big poppa pump is offline
post #23 of 207 (permalink) Old 02-14-2013, 04:25 PM
GilaMinumBeer's Avatar
Depends. My 04' Aero just uses Black RTV for the sealant/gasket. Available at any auto parts store. Heck, even WalMart.
04' Honda Shadow Aero: Mutazu, Harley Davidson, Dynojet, Vance and Hines, Tiny Tach, Shindengen, Progressive, EBC, Colorite, Edelbrock, TJBC, Emgo, Optimax, and Metzeler.
GilaMinumBeer is offline
post #24 of 207 (permalink) Old 02-14-2013, 04:27 PM
hondabond 4 doesnt have any setup time. i usually smear the lightest coat on the case i can, put it back together, by the time i am done bolting everything up fill it with oil and roll
TCazes is offline
post #25 of 207 (permalink) Old 02-23-2013, 11:26 AM
Warning right up front: this is a noob question, but can this mod be done on a '95 Shadow Spirit 1100 as well? Is there much difference in the process?
I realize they are completely different motors and all, but you have done such a good job with the write up, and have made it look so easy, that I can't see why I wouldn't want to do this on my 1100, if possible...
Thanks!
ndshadowrider is offline
post #26 of 207 (permalink) Old 03-01-2013, 04:20 AM
Should work the same. Both engines are similar design.
Ride Safely,
Ed
Ed in Jeffersonville, Indiana
MSF Rider Coach
Proud Viet Nam Vet U.S. Army
Retired U.S. Air Force
Total Disabled Veteran
Journeyman Machinist, Certified Welder
Streetrod Enthusiest
Patriot Guard Rider
hurst01 is offline
post #27 of 207 (permalink) Old 03-01-2013, 05:34 PM
SuperboyX's Avatar
Model: Vt750 Ace
Year: 2002
Send a message via MSN to SuperboyX
I used the Barrett Clutch Springs which are slightly heavier gauge and taller. These are recommended by who knows if you have done the sprocket mod which puts more load on the clutch at takeoff.
AcedIt. Did I see you using permanent lock tight on the magnetic pickup? What if someone wants to change it. It's high heat permanent = pain in ass.
2002 Honda Shadow VT750 ACE Custom.
***HondaShadow.Net Patch Order Info***
SuperboyX is offline
post #28 of 207 (permalink) Old 03-01-2013, 07:31 PM Thread Starter
Aced It's Avatar
Re: How-To: 4° Advance Timing and Clutch Spring Upgrade
AcedIt. Did I see you using permanent lock tight on the magnetic pickup? What if someone wants to change it. It's high heat permanent = pain in ...
I do make clear that blue should be used. Red is all I had at the time and when used very sparingly it is not as permanent as you think. And who else is going to mess with it but me?
82 CB900C - CB Lingo for My Road
82 Magna - My Road is Magna-ficent!
91 VLX - My Road to Bob
03 ACE - My Road to Rod
"Keep the rubber side down, unless of course you have a rubber head!"
Aced It is offline
post #29 of 207 (permalink) Old 03-01-2013, 07:53 PM
SuperboyX's Avatar
Model: Vt750 Ace
Year: 2002
No one I suppose. My bike will end up in a air tight glass case revolving in my living room when I'm finished riding it. One owner always. LOL.
post #30 of 207 (permalink) Old 03-01-2013, 07:56 PM
This might seem obvious, but I'm assuming that my '99 ACE has a regular gasket. Is there any reason I shouldn't simply replace it with liquid gasket when I do this job? It seems a lot easier than ordering a gasket, especially since I'm not a fan of giving the stealership money.
Just ride
Rob Walker is offline
How much timing advance 95shadow1099 Technical Discussion 34 09-20-2012 02:46 PM
99 vlx timing advance bjg928 Technical Discussion 12 04-25-2010 09:56 PM
How to Advance our Timing ? rrounds Technical Discussion 3 01-22-2010 05:16 PM
Timing advance? txmetal Technical Discussion 12 01-31-2008 11:23 AM
Timing advance question morepower Technical Discussion 2 01-06-2007 07:07 PM
