How to disassemble turn signal - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 14 (permalink) Old 04-27-2014, 08:33 PM Thread Starter
tbfoto's Avatar
I have put quite a bit of force trying to "unscrew" this but I don't want to break it. So can someone tell me how do they come apart?????
2002 Honda Shadow VLX 600 Deluxe - Lost but not forgotten.
tbfoto is offline
post #2 of 14 (permalink) Old 04-27-2014, 09:21 PM
Sparkman's Avatar
Just a wild guess. You may have to remove some of the guts inside the cup. Is there a nut inside under that piece of metal where the wires go into the cup? Or maybe lefty tighten and righty loosen.
2003 VT750DC Shadow Spirit
Sparkman is offline
post #3 of 14 (permalink) Old 04-27-2014, 09:25 PM
Scared's Avatar
Model: BMW K1200GT
Year: 2003
Take out the two screws inside and pull out the guts. That back plate has a clip on the left side that is holding the rubber. At least thats how i remeber it. Its been a little while since Ive had mine apart.
2002 750 ACE DELUXE: Sold
2003 BMW K1200GT
Ride Bell by Old Dad
Ride Bell by Gnarly
Ride Cross by "Captain D"
Scared is offline
post #4 of 14 (permalink) Old 04-27-2014, 09:29 PM
derekt78's Avatar
Location: Dallas, GA in the metro Atlanta area west of downtown.
That's where I'm leaning. Are you using these in the rear? If so you need to change the lense to red.
derekt78 is offline
post #5 of 14 (permalink) Old 04-27-2014, 09:50 PM Thread Starter
tbfoto's Avatar
Yes , I want to use these on the rear. My rear turn signals are amber just like these.
tbfoto is offline
post #6 of 14 (permalink) Old 04-27-2014, 10:27 PM
TEngle's Avatar
Indiana - any shade between red and amber
see IC 9-19-6-17
Indiana Code 9-19-6
VT1100 Manuals
https://skydrive.live.com/redir?resi...CHKWhOWhw9k2i8
_____________________________________________
1995 VT1100C2 ACE
Motorcycle Accident Dec 19, 2012
http://s736.photobucket.com/user/tee...t%202012-12-19
TEngle is offline
post #7 of 14 (permalink) Old 04-27-2014, 11:55 PM
h13man's Avatar
see IC 9-19-6-17
Indiana Code 9-19-6
So hows this get a turn signal apart? I only seen amber on the rear as long as I can remember. My 71' CL 100 are amber.
71' CL 100 "Lil' Sista"
99' Valkyrie "Adele"
05' 1600 Vulcan "Ludabelle"
Ride Bell by "Yoman"
h13man is offline
post #8 of 14 (permalink) Old 04-27-2014, 11:58 PM
Furball Zen's Avatar
The two screws and then pull on the upper part that wedges the rubber into the housing. Wait, those are 1157 sockets, you cant use an amber bulb as a tail/running light. If you want to do this you need to put a clear lens and use a red bulb, preferably an LED bulb as incandescent colored bulbs are usually too dim.
I am the Mighty Furball. Hear me fluff.
I can only be responsible for what I say, not what you understand.
Furball Zen is offline
post #9 of 14 (permalink) Old 04-28-2014, 08:30 AM Thread Starter
tbfoto's Avatar
These have a clear bulb and amber lenses. This is what comes stock on the rear of the VLX. I'm going to use these just the same. These are turn signals..... Not tail lights.
tbfoto is offline
post #10 of 14 (permalink) Old 04-28-2014, 06:50 PM Thread Starter
tbfoto's Avatar
So I have figured out how these come apart and have taken some photos along the way. I will make a thread about it all when I'm done. Right now I have another question.
Can I cut and splice into my wires without having to disconnect my battery? If the key is off I shouldn't have any voltage flowing right??? Taking the leads off the battery on my VLX is not easy to get to.
tbfoto is offline
Anyone disassemble switchblade? Dingo. General Bike Discussion 3 04-15-2013 07:40 PM
How to disassemble petcock on 02 shadow 750 ACE? darksandz Technical Discussion 12 06-03-2012 04:21 AM
rear turn signal to turn signal/running light conversion Shadowin'WNC Technical Discussion 3 02-18-2010 04:54 PM
Disassemble laced wheels before painting? mac3687 Technical Discussion 8 08-29-2008 08:17 AM
86 vt700. how do I disassemble the speedometer housing? jchargu3 Technical Discussion 3 02-18-2008 04:07 PM
