VT1100 C-another charging issue - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 5 (permalink) Old 04-28-2014, 10:22 AM Thread Starter
Flying Greg's Avatar
Battery died and left me stranded last week. Recharged battery and checked voltage while grinding starter and voltage did not drop below 11.0V so i think battery is OK. Checked voltage at battery while bike is running and have 14.1 at idle, drops to 12+/- while holding steady at about 3500 rpm then suddenly drops to about 6-9 V after about 30 seconds at higher rpm. Is regulator engaging and reducing voltage to battery because it us fully charged, or do I have some other problem?
I will be checking the yellow wires under the seat for burned or corroded connections that I have seen on this forum, but I am concerned about the voltages at the battery at 3500 rpm. I think they should be higher.
I have also been reading about upgrading the regulator/rectifier to an aftermarket MOSFET unit. Any thoughts about this is also appreciated.
Greg
...Nothing in moderation...
Greg
Flying Greg is offline
post #2 of 5 (permalink) Old 04-28-2014, 10:43 AM
They should kind of work the other way around but within a more tolerable spec. It should be somewhere in the neighborhood of 13 - 14 volts at idle and higher to a peak of less than 15v at 5k rpms. You're r/r is no good, its shunting voltage when it shouldn't hence you're low reading. Replace it with a newer MOSFET style r/r and you will be good to go.
But if you want to be more thorough to make sure your stator is good, check AC voltages across the yellow wires (2 at a time) and it should be around 20vAC at idle and upwards of 50-60vAC around 5k rpms. If that checks out, then it is your r/r for sure.
Damian
Image is pointless if you don't do the riding part; get out on the road and out of the bar!
'00 Sabre
damian.garcia83 is offline
post #3 of 5 (permalink) Old 04-28-2014, 10:48 AM
Da Skipper's Avatar
Check the three yellow wire connections and stator. If they all check out ok, then I recommend the Mosfet upgrade. Even with a new battery, I was still using a battery tender regularly during the riding season, with the stock R/R on my Sabre. After the Mosfet upgrade, I have not needed the battery tender at all. Battery stays charged. I also added a digital voltmeter to keep an eye on the voltage. The Mosfet R/R solved my charging system weakness.
2000 Shadow Sabre VT1100 C2
Da Skipper is offline
post #4 of 5 (permalink) Old 04-28-2014, 11:20 AM
adlowe's Avatar
Originally Posted by Flying Greg View Post
...or do I have some other problem
You need to go through the diagnostics to find out. All we can offer is guesses and opinions.
Sounds like you have a voltage meter. Is it a multimeter? Or do you have one? If not, get one. (Digital is better but analog will work just fine.)
This post has some links to diagnostic how-to videos.
Art's 1999 Shadow 1100 ACE (Ride bell by Dr. Bob's Patient)
adlowe is offline
post #5 of 5 (permalink) Old 04-28-2014, 08:42 PM
i had a charging issue on my 99 ace 750, went with the mosfet upgrade and glad i did, no problem starting and charging. one of the better upgrade for your bike
AZIAN69 is offline
Another Charging Issue tendrew7 Technical Discussion 7 09-04-2014 06:30 PM
'94 Shadow VT600 Battery Charging Issue Spamcan Technical Discussion 10 06-05-2010 10:05 PM
charging issue hondaadventure Technical Discussion 11 06-02-2010 09:40 AM
Battery charging issue TomVa43 Technical Discussion 5 04-05-2010 11:17 PM
Help!!? Older Shadow... Charging Issue.. All New Stuff! sdowiat Technical Discussion 12 12-08-2009 07:44 PM
