Cluth Cable Keeps tightening - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 4 (permalink) Old 06-23-2015, 11:04 PM Thread Starter
aaron_jo's Avatar
Send a message via Yahoo to aaron_jo
So I just finished installing new throttle cables. Thankfully I got to them before they snapped. One was down to only 2 threads. Yikes.
Anyway, I had my left handlebar turn signal switch and mirror sitting upside down, resting on my front tire for about a day or a bit more while I installed the new cables.
When I reinstalled my switch, I noticed my clutch was really tight (no freeplay) and I had to adjust it at the bottom adjuster. No problem. However, next day my clutch was back to being tight again. I did not ride it over this period. I was just messing around with installing my handlebar and switches in the right place.
I followed the clutch line from the top to the bottom and it seems like the line is not kinked or rubbing on anything.
I've since adjusted the clutch again with enough freeplay and it seems fine now. I rode around a bit and it seemed different, but probably just because it was adjusted a bit differently.
I was wondering if anyone has any thoughts why the cable became tight twice without really doing anything to it?
2007 VT750DCA Shadow Spirt
aaron_jo is offline
post #2 of 4 (permalink) Old 06-24-2015, 12:46 PM
Furball Zen's Avatar
Could have kinked it.
I am the Mighty Furball. Hear me fluff.
I can only be responsible for what I say, not what you understand.
Furball Zen is offline
post #3 of 4 (permalink) Old 06-24-2015, 07:04 PM
TenDollarBill's Avatar
Did one of the ends of the housing slip out of the hole it sits in?
Life doesn't care if you're unprepared.
TenDollarBill is offline
post #4 of 4 (permalink) Old 06-24-2015, 07:11 PM Thread Starter
aaron_jo's Avatar
I looked and I really don't think so. I can't really see the one on the lever, but definitely not on the bottom. I've been riding around since all this work and it feels fine so far. I'll update if anything changes.
Thanks for your input.
aaron_jo is offline
New Guy with Cluth questions sassr21 Technical Discussion 10 10-16-2013 04:13 PM
cluth issue mjsawco Member Introductions 5 07-12-2012 10:43 PM
cluth control sticking 2T2 Crash Technical Discussion 6 02-21-2011 04:07 AM
'83 Cluth Not "Clutching" Ugly '83 Technical Discussion 3 07-11-2008 09:56 PM
How to lube cluth cable? Jim Mann Technical Discussion 6 04-20-2008 11:55 AM
