Transmission issue? - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 13 (permalink) Old 08-22-2016, 11:16 PM Thread Starter
Tropicheat's Avatar
Transmission issue?
So while on my way home, I was coming up on a red light so I let off the throttle pulled in the clutch and began braking and downshifting. While still rolling at about 10 with the clutch pulled in the bike got stuck in neutral I tried to push the lever down and it just made a grinding sound so up shifted back to second then tried it again and it was fine. It did not do the rest of the ride home. Is this a thing that happens sometimes or is something off?
Tropicheat is offline
post #2 of 13 (permalink) Old 08-23-2016, 12:36 AM
swifty2014's Avatar
Model: Vt750
Year: 1983
Did you try to down shift very gently?
Sometime even at 10 MPH the gears have a hard time engaging unless you snap them in. Upshifts can be touchy also if done slowly. Just a guess.
1983 750 Shadow
From the past=
1951 Cushman scooter
1962 Honda 305 Dream
1965 Honda 305 Dream
1971 Honda 175 scrambler
swifty2014 is offline
post #3 of 13 (permalink) Old 08-23-2016, 01:00 AM Thread Starter
Tropicheat's Avatar
I tried twice and it would go but after going back up to second and the immediately trying it again it shifted just fine, I held the clutch in the entire time. I guess it's just one of those things that happens rarely. It worked fine the rest of the ride and I stopped at like 8 more lights so unless it starts happening frequently there's nothing to worry about. Machines have hiccups sometimes.
post #4 of 13 (permalink) Old 08-23-2016, 01:04 AM
TenDollarBill's Avatar
A couple of things come to mind. First, is the clutch out of adjustment? If it's not fully disengaging, first gear might be harder to engage, and the grinding suggests the clutch isn't releasing completely. Next, try "double clutching" between second and first.
Good luck.
Life doesn't care if you're unprepared.
TenDollarBill is offline
post #5 of 13 (permalink) Old 08-23-2016, 01:16 AM
swifty2014's Avatar
Model: Vt750
Year: 1983
It always amazes me how well these transmissions work since they are hard steel pieces jamming into other hard steel pieces while they are moving. No syncromesh on these crash boxes but they work so well !
Here is a basic video=
1983 750 Shadow
From the past=
post #6 of 13 (permalink) Old 08-23-2016, 01:26 AM Thread Starter
Tropicheat's Avatar
Good luck.
I know it was disengaged because it went from 4-3 3-2 smooth it just got stuck in neutral when I tried to go from 2-1. It only happened once though.
I may have let the clutch out a little inadvertently I don't know.
post #7 of 13 (permalink) Old 08-23-2016, 09:26 AM
adlowe's Avatar
It's a thing that happens. About 10 MPH could be too fast for shifting into first. The max speed for that is going to vary based on a number of factors but when you're going too fast to downshift you'll hear (and feel) that grinding noise. You could probably force it into first if you wanted. Maybe. I wouldn't.
Art's 1999 Shadow 1100 ACE (Ride bell by Dr. Bob's Patient)
adlowe is offline
post #8 of 13 (permalink) Old 08-23-2016, 10:21 AM Thread Starter
Tropicheat's Avatar
I shift to second at 20 so I don't think 10 is too fast for first. I think it just got stuck in neutral for. Some reason .
post #9 of 13 (permalink) Old 08-23-2016, 10:34 AM
adlowe's Avatar
You said "about 10" which could be as much as 15 MPH? Add in that motorcycle speedometers overstate by as much as 10% to 12% and maybe it could be closer to 20 MPH?
Try downshifting into first at 30+ MPH and you'll know that the grinding noise is what you get whenever you try while going too fast. The bike wasn't stuck in neutral; you were moving too fast for the gears to engage in first.
adlowe is offline
post #10 of 13 (permalink) Old 08-23-2016, 11:21 AM
h13man's Avatar
I'm still curious if the clutch is adjusted right but no answer on this matter. 3/4" end play on the lever or a nickle width at the pivot gap. Never had an issue with a Honda (11) in 46 yrs. unless the clutch wasn't adjusted right. Did have to shim clutch springs twice but that a different issue altogether.
71' CL 100 "Lil' Sista"
99' Valkyrie "Adele"
05' 1600 Vulcan "Ludabelle"
Ride Bell by "Yoman"
h13man is offline
85 VT 1100 Transmission Rebuild. MarktheMoose Technical Discussion 9 10-31-2010 05:20 PM
Converting from 4 speed transmission to 5? agudenkauf Technical Discussion 7 11-27-2007 10:30 PM
transmission engage sound Simpdad Technical Discussion 3 10-17-2007 06:48 PM
clutch/transmission? gyoung Technical Discussion 2 07-25-2007 01:45 PM
VLX 5 Speed transmission ? Shock Technical Discussion 3 06-03-2007 02:39 PM
