Loud tappet tick on ACE 1100 suspect clogged oil passage? - Page 2 - Honda Shadow Forums : Shadow Motorcycle Forum
post #11 of 19 (permalink) Old 09-07-2016, 12:49 PM
swifty2014's Avatar
Model: Vt750
Year: 1983
Another thing I found was an oil supply bolt to the heads called an oil orifice bolt that has a banjo fitting and supplies the upper areas. I was going to take it out to see if it could be clogged but decided if it was plugging up, there would be much more clatter and oil starvation than one tick that I have. Just some info. since it could be an area that would slow down the flow to the heads.
1983 750 Shadow
From the past=
1951 Cushman scooter
1962 Honda 305 Dream
1965 Honda 305 Dream
1971 Honda 175 scrambler
swifty2014 is offline
post #12 of 19 (permalink) Old 09-07-2016, 12:56 PM
swifty2014's Avatar
Model: Vt750
Year: 1983
I have to retract that last statement about the oil orifice bolt. I just looked at it better, and it actually feeds the trans and clutch areas. So it shouldn't have an effect of oil pressure to the heads.
1983 750 Shadow
From the past=
post #13 of 19 (permalink) Old 09-11-2016, 12:34 PM Thread Starter
bikenut's Avatar
Anyone know the thread size of the oil pressure switch? I would like to hook up a gauge, is this standardized?
I put in 3 ounces of SeaFoam and the tick went away, temporarily. I will put another 100 miles on it before I draw any conclusion from the cheapo-fix.
1997 American Classic Edition Shadow VT1100 C2
bikenut is offline
post #14 of 19 (permalink) Old 09-12-2016, 12:29 AM
h13man's Avatar
If the tick went away, change the oil now and see what happens. I wouldn't leave the Seafoam in much longer than necessary but thats me.
71' CL 100 "Lil' Sista"
99' Valkyrie "Adele"
05' 1600 Vulcan "Ludabelle"
Ride Bell by "Yoman"
h13man is offline
post #15 of 19 (permalink) Old 09-12-2016, 12:37 AM
swifty2014's Avatar
Model: Vt750
Year: 1983
The oil pressure threads on USA fittings are an 1/8 pipe thread. On metric engines they are a 1/8 British pipe thread that is very close but not exact. A US 1/8 pipe will screw in a few threads and most of the time would be good enough for testing purposes and not ruin the Metric threads. Put some teflon tape on to help seal.
1983 750 Shadow
From the past=
post #16 of 19 (permalink) Old 09-14-2016, 01:41 PM Thread Starter
bikenut's Avatar
Thank you swifty that is exactly what I need to know.
The plan is to run one tank or 150 miles on seafoam plus a few ounces of marvel mystery oil as the tick has subsided, will follow up with fresh Castrol GTX 10W40.
bikenut is offline
post #17 of 19 (permalink) Old 10-07-2016, 10:52 PM Thread Starter
bikenut's Avatar
A follow up on this thread to say the seafoam seems to have worked. Ran 130 miles and then changed to fresh 10W40; no more noise from the lifters.
bikenut is offline
post #18 of 19 (permalink) Old 10-08-2016, 07:44 AM
sidejam's Avatar
Gotta love it when the "mechanic-in-a-bottle" fixes the problem!
sidejam is offline
post #19 of 19 (permalink) Old 10-08-2016, 09:14 AM
Gnarly's Avatar
Simply love that stuff!
Works overnite, one application, when B12 or Seafoam would take a week.
Tractor Supply usually has it; sometimes Home Depot.
And small engine repair places.
-Gnarly
( because everything looks the darkest, right before it goes completely black)
~~~Ride safe; ride smart....in memory of the one and only 7x~~~
The VT1100C2 ACEs: the '97 Flyin' Jenni, rescue dog Hobo LongNose, and the '96 on the right.
[IMG][/IMG]
Gnarly is offline
3rd post - Sabre blocked pilot jet passage thedaveness Member Introductions 3 07-24-2017 12:02 AM
Tick tick sound 1999 1100ACE Brooksie Technical Discussion 7 03-25-2012 01:20 PM
Carb passage blocked? Vt1100 honda. Buicknick72 Technical Discussion 5 01-23-2012 03:42 PM
Tick Tick Tick GREGMCKEE Technical Discussion 3 05-12-2008 09:10 PM
Tick, tick, tick Len Klajda Technical Discussion 1 10-13-2007 03:55 PM
