starter ghost problem - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 29 (permalink) Old 02-03-2007, 07:15 PM Thread Starter
well i went to start my bike up for the first time today after tuning it up and taking care of some minor things.
i put a battery on that i know was fully charged (had been on a trickle for about 8 hours) when i went to hit the ignition switch i heard a click and my lights dimmed but no turn over.. just a click
i got my truck and tried to jump it with the truck on and still same thing the lights dim, i hear a click, but nothing please help me im dieing to test her out.
i had her up on the integrated work stand does that affect the starting?
s3v3rth3stars is offline
post #2 of 29 (permalink) Old 02-03-2007, 07:29 PM Thread Starter
update: i am a new rider this is my first bike so please dont laugh at me for this butt...
my neutral light wont come on the dash, could it be a neutral safety switch impeding my start? how do i make sure the light comes on?
post #3 of 29 (permalink) Old 02-03-2007, 07:50 PM
Can you pull in the clutch and click the shifter up or down until the neutral light comes on? You may need to roll the bike slightly while doing this to make sure the shift takes place. If the neutral light doesn't come on you might try shifting all the way down multiple times (to be sure you are in first) and then just slightly up to find neutral. Roll the bike to make sure. Some bikes also have a safety switch in the clutch lever housing, so you might also try pulling in the clutch when you try to start.
The symptoms you describe of lights dim and a click makes me think it is something besided the neutral switch though. I would double check the battery connections to make sure they are secure and that the battery ground cable is making a good ground.
Riding for the Son.
Current Bikes: 2003 Spirit 1100, 2008 GSX650F, 2006 Suzuki GS500F, 1996 Kawasaki KLR 250, 1974 Yamaha DT250
ShadowDave is offline
post #4 of 29 (permalink) Old 02-03-2007, 08:16 PM
mark v's Avatar
Trickle chargers are not battery chargers. A Trickle charger can charge a battery but it can tale 24 hours depending on how dead the battery really is.
Trickle chargers are designed to maintain a battery bu charging it very SLOOOOOWW!
mark v is offline
post #5 of 29 (permalink) Old 02-03-2007, 08:26 PM Thread Starter
i also tried to start it while being hooked up too the truck and the same thing happened so im gonna try to get that neutral light to come on.
edit:i popped it into neutral but still no neutral light on the dash.. what could this be?
post #6 of 29 (permalink) Old 02-03-2007, 09:06 PM
Gonzo's Avatar
Jumper those wires on the neutral switch and see it that helps...
also check that the Stop/Run switch is in teh Run position.
Gonz
When does it end? It doesn't....it's a Vicious Cycle!!
Gonzo is offline
post #7 of 29 (permalink) Old 02-03-2007, 09:14 PM
Maybe the neutral switch isnt working? Maybe a bad ground or connection to the switch? With the light not comeing on, it makes me suspicious that it's in the neutral switch part of the circuit.
Could be a bad connection to the clutch diode too. The diode is tied in with the neutral switch as well as the clutch switch. The diode would be located in the fuse box, you should be able to pull it out and push it back in to freshen the connections to it a bit. It should be black and rectangular in shape.
Myabe I'm wrong here, I'm looking at a much newer schematic. I hope you get the problem fixed.
Mark
2004 Shadow Spirit 1100
2000 Valkyrie
zikzak is offline
post #8 of 29 (permalink) Old 02-03-2007, 09:45 PM Thread Starter
ive tried pulling the fuses and moving the bike around but still the light wont come on.. this is a real buzzkill id hate to have to take it somewhere.
post #9 of 29 (permalink) Old 02-03-2007, 09:50 PM
With your tune up I'm assuming new plugs, if not might be bad plugs? Also Make sure the kill switch is on the "run" position.
Battery cables properly on?
Kick stand up?
Shadow Kat
2001 750 Shadow ACE
It is the honor & duty of the strong to protect the weak.
Shadow Kat is offline
post #10 of 29 (permalink) Old 02-03-2007, 10:42 PM Thread Starter
well it cant be a plug yet because my starter isnt even turning its just clicking, i have no clue what to do im stuck, id pull the starter but its not turning at all, just clicks.
Starter or Starter-Switch problem...bike not staring every time LuckyTheRockstar Technical Discussion 17 01-01-2014 02:09 PM
Ghost ~ VS ~ Easy brackets - Lets hear it. Zen Dragon General Bike Discussion 1 04-12-2007 08:27 PM
Any one w/ ghost or easy brackets? Shadow Kat General Bike Discussion 16 04-08-2007 01:08 AM
Ghost Rider Movie Opened Friday (Yesterday) blueeyes2114 General Bike Discussion 12 02-18-2007 04:18 PM
Ghost Rider - another bike movie coming out downinit25i General Bike Discussion 27 01-28-2007 12:04 PM
