Anyone lower their backend 1.5"? - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 11 (permalink) Old 02-04-2007, 08:15 PM Thread Starter
bikervas's Avatar
Anyone lower the backend of their bike using the scootworks 1.5 lowering kit? Kind of worried that if I go with the 2.5, I won't be able to get my motorcycle lift/jack underneath the frame.
For those that have lowered the bike 2.5", how much lower is it at the mid point of the bike underneath the frame?
2002 Honda Shadow ACE 750
Ride bell by Kara
bikervas is offline
post #2 of 11 (permalink) Old 02-05-2007, 08:01 AM
Well, I can tell you that with the 2.5 kit, it lowers the bike just enough that my bike lift will not roll under the bike. That is easily remedied by rolling the rear tire up on a brick. It gets the frame high enough to get the lift under the bike.
AERO_HEAD is offline
post #3 of 11 (permalink) Old 02-05-2007, 05:50 PM
I installed the rear lowering kit (2.5) a month back, I haven't driven it yet (to cold), although I haven't installed the front yet, I measured the frame to ground and it is one inch lower then stock, The front may lower it more, I'm not sure.
I got my jack from Canadian tire, (made by motomaster) and it still goes under, alittle harder to do, but it still works.
Epic is offline
post #4 of 11 (permalink) Old 02-07-2007, 07:30 PM
Well, my backend did drop a bit when I turned 50, but I never thought to measure how far it dropped
Come to think of it, I've noticed a lot of things that have dropped.
MarkC
#27 in W.M.R
MarkC is offline
post #5 of 11 (permalink) Old 02-17-2007, 12:47 PM Thread Starter
bikervas's Avatar
I decided to email Scootworks and asked them the question of frame to ground clearance as I am concerned about this issue.
They responded by saying,
"this kit will not change the frame to ground clearance. There will be no change as you are not changing the property of the shock."
Is that so? How do these lowering kits work? Is the top half of the frame independent to the bottom half?
Anybody else have a different view point?
Ride bell by Kara
bikervas is offline
post #6 of 11 (permalink) Old 02-17-2007, 09:54 PM
I would have to disagree with that response. When I lowered my ACE with the SW kit I found that my bike no longer had much "lean" when placed on the sidestand. This tells me that the frame is indeed lowered. In fact, I don't see how this aspect of the bike could otherwise be affected. I only used the rear kit although I bought the front kit as well. HTH
JimC in NC
Rider #31 in Woody's Journal Ride
'99 750 ACE, V&H Cruzers, Kury ISOs, Mustang seat, Leatherlyke Bags
'85 Goldwing LTD-"The Smooth Ride!" (now gone but not forgotten)
JimC in NC is offline
post #7 of 11 (permalink) Old 02-18-2007, 10:10 AM Thread Starter
bikervas's Avatar
I think that I would agree with you. Having a look at the schematics, the rear tire is bolted to the swingarm which pivots on the frame. The upper shock is connected to the frame which is fixed. I am not sure why Scootworks would suggest this?
Thanks for your $0.02
Ride bell by Kara
bikervas is offline
post #8 of 11 (permalink) Old 02-18-2007, 11:19 AM
It does lower the frame, I like how Scootworks response was that it doesn't lower the frame, and yet when I opened my Front lowering kit they say on the instructions that any lower then 2 inch and the kickstand must be modified.
Epic is offline
post #9 of 11 (permalink) Old 02-19-2007, 04:19 PM Thread Starter
bikervas's Avatar
I sent an email back to Scootworks asking for clarification:
"Just wondering, I think there is a discrepancy in opinion here -
https://www.hondashadow.net/forum/viewtopic.php?t=41198
Can you please confirm?"
They response was:
"I am checking on this for you-- maybe there is a misunderstanding here on my part. I will get back to you...
Here is clarification on the lowering kit. Hope this helps!!!
If you lower the rear 1-1/2", the engine area will be about half that
(3/4") closer to the ground. If they lower the front and rear 1-1/2",
the engine area will be about 1-1/2" closer to the ground. We've not
had any complaints, out of the thousands of these things we've sold,
about the inability to get bikes on lifts after using our kits."
There it is.
Ride bell by Kara
bikervas is offline
post #10 of 11 (permalink) Old 03-03-2007, 12:23 PM
i used the scootworks kit and am very happy with it. i adjusted the rear shocks to setting #5 and no bottoming out. mine is the 2.5" setup I can email pics if interested
1radtoy is offline
Does anyone else "Summer" their bike? Fantod General Bike Discussion 15 08-31-2016 06:17 AM
To lower or not to lower.... Bufftub Technical Discussion 11 07-04-2016 07:32 AM
Anyone "Bob" their 80's shadow (#3) The Papa Member Introductions 8 09-16-2011 12:04 AM
Be Seen"""LQQK"" SHADOW 1100T General Bike Discussion 9 04-27-2008 06:04 PM
Anyone have "XM" INNO mounted on their bike charliemac General Bike Discussion 1 01-08-2008 10:27 PM
