Aftermarket rims - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 11 (permalink) Old 04-25-2017, 08:58 PM Thread Starter
Hr2burn's Avatar
Aftermarket rims
When weighing all the considerations on having my rim powder coated, aftermarket rims are sounding more appealing. I could go 16" rear, get a black rim with Crome spokes and even upgrade to a disc brake. Anyway, the biggest issue I'm unsure of is side to side alignment and axles size, though the bearings I could find a good combo and do something with the spacer.
Has anyone gone down this path? The whole point of buying this bike and building it from ground up was to have a bunch of fun and do everything. I want the rim swap but only with a reasonable amount of headache. Anyone have knowledge? Gearing and the effect of tire rim size of no concern.
Hr2burn is offline
post #2 of 11 (permalink) Old 04-25-2017, 09:12 PM
smurfy71's Avatar
Tape off the tire and spokes and plasti dip the rim.
Sitting on my Shadow making vroom vroom noises.
2006 Shadow Aero 750, "Audrey" - Jan 2017 BOTM - Sold Oct 2018
2008 VTX 1300T - Oct 2018 Co-BOTM
smurfy71 is offline
post #3 of 11 (permalink) Old 04-25-2017, 09:21 PM
Aftermarket rims are big money and there are only a couple of companies that make them to fit Honda's. As far as disk brakes, that would be an easy job because more then just simply adding disk brakes. t may take modifying the swingarm as there were no VLX with rear disk.
jpr1968 is offline
post #4 of 11 (permalink) Old 04-26-2017, 12:01 AM
GB6049's Avatar
Model: Shadow Spirit VT750 DC
Year: 2006
As jpr said, the wheels will be the big expense unless you can score some take off. HD wheels are available and should be easily modded to fit the VLX similar to the VT750 DC. It took me about a week after collecting all the parts to assemble it. A machine shop turned the axles down to fit the HD bearing ID and cut the spacers after I lined everything up. A custom sprocket from Rebel gears until I had an adapter made to take advantage of steel sprockets and not aluminum. Washers used to shim the front caliper out to fit and at first moved the stock speedo to the rear wheel before going GPS a few years back. Search Harley wheel mod or CBR wheel mod.
GB6049 is offline
post #5 of 11 (permalink) Old 04-26-2017, 09:35 AM Thread Starter
Hr2burn's Avatar
Thanks GB, I'll look for your thread. I'm curious why not just get bearings that have an OD to fit Harley rim and ID to fit axle rather than machining down axle? Then I'm thinking of either cutting down stock spacer (the one inside hub) or just making a new one depending on new hub width.
Also you mentioned a custom sprocket adapter. Why not use a steel Harley sprocket? Speedo won't be a problem as I went MotoGadget everything wired/electric.
Good info, thanks.
Hr2burn is offline
post #6 of 11 (permalink) Old 04-26-2017, 11:34 AM
You could only use a Harley sprocket if it matched the front sprocket profile and that aligns properly with the front sprocket. In other words, both sprockets have to match the chain that is being used.
jpr1968 is offline
post #7 of 11 (permalink) Old 04-26-2017, 03:09 PM
PhantomRider64's Avatar
Model: Phantom
Year: 2013
I went from a 160/80-15 to a 170/80-15. I cannot remember total diameter difference, I think 1" taller, it made a 4 mph difference. Indicated on the speedo is 61 mph, indicated on the GPS is 65 mph.
Sent from my SM-S920L using Tapatalk
There is nothing like your knees in the breeze!!!
2013 Shadow Phantom "Draco Vide"
Previous Bikes
1995 Suzuki VS800GLS Intruder
1982 Suzuki GS450L
Ride Bell By Old Dad.
Ride Cross gifted from Captain D
PhantomRider64 is offline
post #8 of 11 (permalink) Old 04-26-2017, 03:39 PM
ABQ-Jammer's Avatar
Model: Spirit 750 VT750DC
Year: 2003
Like @GB6049 suggested, do a search for Harley wheel mod or CBR mod, and you should get the info you need on how to do it. Like others have said, though, getting new wheels, no matter which way you go, is going to be the expensive part. If you can just mod/paint/powdercoat your current wheels, you will definitely save some SERIOUS cash! You might also check on Magna or other older Shadow wheels, which could be the exact same size and need little modifications to fit to the bike, but would allow you to change from spokes to mags, if you want.
(((=-JammeR-=)))
Ride Bells by blue flames & shadowride69 (THANKS!!)
'13 Harley Dyna Super Glide (FXDC)
ABQ-Jammer is online now
post #9 of 11 (permalink) Old 04-26-2017, 09:49 PM
GB6049's Avatar
Year: 2006
Good info, thanks.
Some did just that. Seems that the victory bearings are supposed to be HD OD and Honda ID. Milling the axle though allowed for more possibilities for a bracket for the brake caliper.
GB6049 is offline
post #10 of 11 (permalink) Old 04-28-2017, 07:12 PM
XXL
XXL's Avatar
Here's my 1988 VT800 with stock front wheel and 18" rear hoop, both powdercoated black, then laced up with new stainless spokes. RAW 18" rear hoop was about $150, spokes (front and rear) about $240, 2 new tires, all bearings (while they're apart), powdercoating, etc., was about $1k total. Obviously a little different bike style than most, but the new wheel setup really transformed the look for me. Before and during pics attached. See after pic in my sig.
Front tire is 100/90-19. Rear is 130/70-18.
Name:	vintage-cafe-racer-caferacer-custom-motorcycle-honda-shadow-vt800c-dime-city-cycles-payback-8_1.jpg
ID:	208457   Click image for larger version
Name:	vintage-cafe-racer-caferacer-custom-motorcycle-honda-shadow-vt800c-dime-city-cycles-payback-52_1.jpg
ID:	208465   Click image for larger version
XXL is offline
Rims rims and more rims. Help please jkustomz28 General Bike Discussion 0 08-02-2013 12:06 AM
Thinking on replacing my stock spoke rims for aftermarket... Enoch Technical Discussion 6 07-07-2009 09:35 PM
Changing to laced rims from mag rims bionic Technical Discussion 0 07-08-2007 07:47 PM
how specific are rims to bike types? meatpopsicle General Bike Discussion 2 06-23-2007 12:55 AM
1100T and Saber rims SHADOW 1100T Technical Discussion 13 05-30-2007 07:58 AM
