No power, currently on the side of the road - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 37 (permalink) Old 05-04-2017, 09:19 PM Thread Starter
Hello all, finally out for a rip, bike was running great, '83 Honda shadow vt750 c. Pulled over to regroup with my buddy so I shut it down. When I went to start it back up, nothing, no lights no power whatsoever. Main fuse is ok, took the battery across the street, it has a full charge. Help!!
WestCooper is offline
post #2 of 37 (permalink) Old 05-04-2017, 09:23 PM
GB6049's Avatar
Model: Shadow Spirit VT750 DC
Year: 2006
Loose ground or bad contact in the switch housing.
GB6049 is offline
post #3 of 37 (permalink) Old 05-04-2017, 09:26 PM
Anywhere near Americus GA???
D
Loose connection is my suspect...
`98 VT750 A.C.E.
ABATE member 40+yrs.
www.ABATEGA.org
(DC District 13)
www.mrf.org
www.MSF-USA.org
http://www.ama-cycle.org/
Enjoying Life,D
"Captain D" is offline
post #4 of 37 (permalink) Old 05-04-2017, 09:57 PM
smilie's Avatar
Did your run/stop switch get moved? Kickstand switch or clutch switch? Scratch the run/stop, it would still turn over.
smilie is offline
post #5 of 37 (permalink) Old 05-04-2017, 10:02 PM Thread Starter
Nothing got moved or adjusted, was running great, turned it off, less than 5 minutes later, turned the key and nothing happened, zero power
post #6 of 37 (permalink) Old 05-04-2017, 10:03 PM Thread Starter
Checked ground, it's solid, looked in switch housing, everything seems fine, no obvious loose connections. Guess I'll have to get towed home and work through the whole electrical system with a multi meter
post #7 of 37 (permalink) Old 05-04-2017, 10:23 PM
smilie's Avatar
It might be a worn ignition key switch. Check your ignition switch to see you have power out when the key is on.
smilie is offline
post #8 of 37 (permalink) Old 05-05-2017, 08:18 AM
I was hoping to see you had found the Gremlin and rode home...
Gotta Bell?
Please post the cure, for those who MAY have a similar problem...
Changing Gas,
D
Coming up on 150,000 miles
`98 VT750 A.C.E.
www.ABATEGA.org
(DC District 13)
www.mrf.org
www.MSF-USA.org
Enjoying Life,D
post #9 of 37 (permalink) Old 05-05-2017, 08:01 PM
GB6049's Avatar
Year: 2006
It is usually just dirty contacts that Ned cleaning and new dielectric grease applied. Matter of fact I need to clean and relive my turn signal.
GB6049 is offline
post #10 of 37 (permalink) Old 05-05-2017, 08:41 PM Thread Starter
Thanks everybody, super funny, I actually put a gremlin bell on my bike before I went for the ride yesterday. What's a good way to work through the electrical system to find the disconnect
83 GR650 I'm currently building rshutchinson Member Introductions 1 09-17-2015 01:48 PM
riding a yamaha currently btorear Member Introductions 1 08-12-2013 06:29 PM
No no no NO NO!!! ... aaagh. Montego Murph General Bike Discussion 13 09-10-2011 10:16 PM
Native Texan, stationed in CO currently in Afganistan EODRay Member Introductions 10 09-07-2011 02:02 AM
