engine quits while riding then nothing... - Page 2 - Honda Shadow Forums : Shadow Motorcycle Forum
post #11 of 17 (permalink) Old 05-18-2017, 12:19 AM
Originally Posted by jwinker View Post
...unless he means the engine "turns over," but doesn't start...
He said the starter was turning.
jpr1968 is offline
post #12 of 17 (permalink) Old 05-18-2017, 07:10 AM
smurfy71's Avatar
He actually said the motor whines, but won't turn.
I think this needs more clarification. Is the starter turning causing the whine? Is the motor seized? I would then be looking at an over heating issue.
Sitting on my Shadow making vroom vroom noises.
2006 Shadow Aero 750, "Audrey" - Jan 2017 BOTM - Sold Oct 2018
2008 VTX 1300T - Oct 2018 Co-BOTM
smurfy71 is offline
post #13 of 17 (permalink) Old 05-18-2017, 09:46 AM
ABQ-Jammer's Avatar
Model: Spirit 750 VT750DC
Year: 2003
Originally Posted by idgeek View Post
wow! thanks for the advices!
What do you mean by "3-yellow wires"?
There are 3-yellow wires, going from the battery or regulator to the stator, with a connector under the seat. It's a common issue on the Shadow bikes for that connector to heat up, burn up, or blacken, causing intermittent or total lack of juice going to the bike, and it happens on practically ALL models. Honda did it that way since it needs 30A at the stator, but to get one wire to handle that much current would take something big and more expensive, so they just run 3 regular wires taking 10A each, instead.
Hope that answers your question.
(((=-JammeR-=)))
Ride Bells by blue flames & shadowride69 (THANKS!!)
'13 Harley Dyna Super Glide (FXDC)
ABQ-Jammer is offline
post #14 of 17 (permalink) Old 05-23-2017, 03:18 AM Thread Starter
Originally Posted by ABQ-Jammer View Post
This could be a couple of things. Like @smurfy71 1 said, it might be the gas tank vent tube being clogged, and taking off the gas cap will let you know if that's what the problem is, as the bike will start and run fine without the cap on, but when you put the cap back on, it will die a little later. Another possibility is the coils. If there is a crack in the coil, it will run fine for a while, until that coil heats up and separates, causing the bike to die, and not be able to start until it's cooled off enough to get closer together so the spark can jump the gap again, and then runs until it heats up and separates and dies again. You should also check the 3-yellow wires, as that can cause all kinds of trouble, including not starting or dying. You can get a replacement for that connector for about $3, if it's burned/fried. Another possibility is the start switch itself. Open the switch housing, and check it for loose wires and good contact, clean it, and put it back together. However, that usually is seen with pushing the start button, and nothing happens but the lights going out.
Okay.. finally made some time to check on the bike!
first of all, I bought this bike about a month ago. and today was the first time I actually opened her up to see what is going on. and wow... she looks a bit different from my other Steed 600.
this is how she looks on the right side...
first what I noticed is that a fuse connector is burned out. and there was a exposed burned 30A fuse. could this be the stater starter relay fuse?
I checked the coils and coils itself was within spec according to the factory service manual. BUT.. the front coil failed the secondary coil resistance.
that's what I found out so far..
thanks for reading.
ID:	213337   Click image for larger version
ID:	213345   Click image for larger version
idgeek is offline
post #15 of 17 (permalink) Old 05-23-2017, 09:27 AM
ABQ-Jammer's Avatar
Year: 2003
thanks for reading.
If it's a 30A fuse, it's most likely for the starter relay. I'd change that first, and see how it does after that. If that alone doesn't make a difference, I might be inclined to have that front coil tested at a shop or simply replace it. I suspect one or the other or both are causing the issue.
BTW, it also looks like PO also replaced the turn signal flasher/relay (the clear round cylinder in there with the two wires going to it), which may have been done if they replaced regular bulbs or turn signals with LEDs or something like that.
(((=-JammeR-=)))
post #16 of 17 (permalink) Old 05-23-2017, 11:53 AM
swifty2014's Avatar
Model: Vt750
Year: 1983
Another fellow here has burned connector on the solenoid and I found this connector and the solenoid on ebay, but from China, only $14.00. That would at least get you back to factory setup again with little work. Probably the connector has burned and lost connections.
Motorcycle Starter Solenoid Relay&Plug Electrical Parts Connector Honda VT250 | eBay
1983 750 Shadow
From the past=
1951 Cushman scooter
1962 Honda 305 Dream
1965 Honda 305 Dream
1971 Honda 175 scrambler
swifty2014 is offline
post #17 of 17 (permalink) Old 05-26-2017, 11:02 AM Thread Starter
thanks everybody for your answers.
After changing the coil, fuel cut relay AND the carburetor(from my other Steed), she srarts and runs great!(for now...)
idgeek is offline
Bike runs, then stops, then runs, then stops . . . DRVMN Technical Discussion 10 08-29-2015 08:19 AM
Bike runs fine then quits... jinxkaiser Technical Discussion 6 08-11-2011 06:59 PM
Intermittant Power Problem - Bike Sputters then Quits Science.Dan Technical Discussion 14 05-25-2011 11:54 AM
Second Question for the Bike Runs then Quits? BlkShadow600 Technical Discussion 2 05-07-2008 02:47 AM
Bike runs but then quits!!! BlkShadow600 Technical Discussion 9 05-01-2008 10:38 AM
