Clutch Replacement Tips and Tricks - Page 2 - Honda Shadow Forums : Shadow Motorcycle Forum
post #11 of 14 (permalink) Old 06-08-2017, 01:57 PM
I bought the Barnett clutch kit that comes in today for my 11 phantom. Is the clutch plate holder tool really necessary to change out the plates? I thought there was another tool recommended too. I have a torque wrench and plan on using that.
kyred85 is offline
post #12 of 14 (permalink) Old 06-08-2017, 09:23 PM Thread Starter
GB6049's Avatar
Model: Shadow Spirit VT750 DC
Year: 2006
Everything went well with removal. Not having spoke wheel I used a tie down strap between the mag spokes and the swing arm to keep the rear wheel from turning thus stopping the tranny from turning. Un staking the nut was tedious but not too bad.
Things went to sh#%*'@t putting the side case back on and installing the clutch cable. Didn't seem like there was enough tension on the clutch spring so, I took the side case back off and figured I needed to give the clutch rod another turn. Doing so snapped the retaining clip off the end of the spring. Waiting on a new spring to try it again since the manual is not very clear on how much tension there should be or if you need to "wind" the spring. The clutch cable was in the middle of the adjustment range so I sure it is not stretched.
GB6049 is offline
post #13 of 14 (permalink) Old 06-08-2017, 09:32 PM Thread Starter
GB6049's Avatar
Year: 2006
Not sure how the Phantom disassembles but some folks have someone sit on the bike and lock the rear wheel brake to stop the tire from turning and loosen the clutch nut. Others made a "tool" out metal plate or wood by drilling a hole large enough for the socket to fit and four holes to bolt the tool to the spring mounting post.
GB6049 is offline
post #14 of 14 (permalink) Old 06-08-2017, 09:34 PM Thread Starter
GB6049's Avatar
Year: 2006
Originally Posted by Harryc View Post
@GB6049 , the wheels on your bike are awesome...just say'in. Great look, and I dig the nutjob pipes too.
Thanks Harry.
GB6049 is offline
83 vt750 front brake tips, tricks, and secrets mattyo Technical Discussion 21 09-18-2013 02:13 PM
Tips and tricks tgelphman General Bike Discussion 14 10-22-2012 05:34 PM
Mechanicing tips/tricks still.southern Technical Discussion 5 02-15-2012 12:32 AM
Any tips and tricks for doing a full drive train change? RBShadow General Bike Discussion 8 05-20-2007 07:23 PM
