Clutch Replacement Tips and Tricks - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 14 (permalink) Old 06-03-2017, 11:17 PM Thread Starter
GB6049's Avatar
Model: Shadow Spirit VT750 DC
Year: 2006
The bike turns 11 years since I bought her and she is just around the corner from 45,000 miles. Clutch has started to slip badly in 1st and 2nd so new EBC clutches go in next week to go with the EBC installed a year or two ago. Any tips, tricks or advice for removal or installation?
GB6049 is offline
post #2 of 14 (permalink) Old 06-04-2017, 01:25 AM
swifty2014's Avatar
Model: Vt750
Year: 1983
My bike is a bit different but I remember many guys talking about the torque on the bolts for the springs only about 9 pounds. And some have broken one off being too strong with them.
1983 750 Shadow
From the past=
1951 Cushman scooter
1962 Honda 305 Dream
1965 Honda 305 Dream
1971 Honda 175 scrambler
swifty2014 is offline
post #3 of 14 (permalink) Old 06-04-2017, 09:19 AM
Dj Smuv's Avatar
get a paper gasket for the crankcase - it just makes **** easier and cleaner
get new crush gaskets for the exhaust
get some 000 steel wool and clean up the backsides of pipes and belly of the crankcase, and while u at it remove the plastic cylinder jugs and use some chrome polish to make every inch look new, while its broken down
Dj Smuv is offline
post #4 of 14 (permalink) Old 06-04-2017, 11:06 AM
sidejam's Avatar
If you can, let the friction plates soak in oil overnight.
sidejam is offline
post #5 of 14 (permalink) Old 06-04-2017, 11:55 AM Thread Starter
GB6049's Avatar
Year: 2006
Thanks Sidejam. I plan to soak them in the oil I drain out and reuse that for a couple hundred miles before changing the oil and filter.
GB6049 is offline
post #6 of 14 (permalink) Old 06-04-2017, 11:58 AM Thread Starter
GB6049's Avatar
Year: 2006
When I put the EBC springs in I used the torque wrench.
GB6049 is offline
post #7 of 14 (permalink) Old 06-06-2017, 09:51 PM Thread Starter
GB6049's Avatar
Year: 2006
Old clutches out and new ones soaking. New center nut arrives Thursday so it should be back together that night.
GB6049 is offline
post #8 of 14 (permalink) Old 06-06-2017, 09:57 PM
Harryc's Avatar
@GB6049 , the wheels on your bike are awesome...just say'in. Great look, and I dig the nutjob pipes too.
"Stormy" 1997 Valkyrie Tourer - http://s724.photobucket.com/user/Har...eshow/Valkyrie
Ride Bell By OldDad
Harryc is offline
post #9 of 14 (permalink) Old 06-06-2017, 09:58 PM
sidejam's Avatar
Good choice on clutch by the way. I replaced my clutch with an EBC clutch and heavy duty springs. So far, very happy with it.
sidejam is offline
post #10 of 14 (permalink) Old 06-08-2017, 01:35 PM
JDLowEnd's Avatar
Pro-Tip: Don't over-tighten the bolts that hold the clutch case to the block! You'll have a bad time!
But it all honesty be careful, and use an even stream of gasket maker when you are putting it back on. I did overtighten one of the bolts and had to have the engine case drilled and tapped!
Also don't over-tighten the bolts that hold the clutch springs down, I had to replace the back plate because of it, and that was a bad time too.
In summary, use a high quality torque wrench and it will save a few headaches!
2007 Spirit 750dc Stage 1-V&H-ThunderMFG-Chameleon Paint
JDLowEnd is offline
83 vt750 front brake tips, tricks, and secrets mattyo Technical Discussion 21 09-18-2013 02:13 PM
Tips and tricks tgelphman General Bike Discussion 14 10-22-2012 05:34 PM
Mechanicing tips/tricks still.southern Technical Discussion 5 02-15-2012 12:32 AM
Any tips and tricks for doing a full drive train change? RBShadow General Bike Discussion 8 05-20-2007 07:23 PM
