'06 Honda Shadow Spirit 750 Issues - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 15 (permalink) Old 06-10-2017, 04:58 PM Thread Starter
Javier Villamil's Avatar
Cool '06 Honda Shadow Spirit 750 Issues
Hello,
As you can tell by this thread title, I drive a '06 Honda Shadow Spirit 750.
I Just about it a few months back and everything seemed fine.
I am new to riding and I am at the very early stages of learning to fix my bike.
The issues:
- Sputtering when throttle
- back firing when start
- odometer flashing on and off
I read a few threads and things were all over the place.
possibilities included:
-sparkplugs
-air intake issues
-electrical issues
Could this be a coolant issue?
Oil?
Easy fixes?
I am just lost as I am such a noob.
Any help would be greatly appreciated
Thanks all!
Javier Villamil is offline
post #2 of 15 (permalink) Old 06-10-2017, 05:07 PM Thread Starter
Also, It just died on me. If that helps with a diagnosis.
I saw some oil or something in the air filter. not sure what that says. I ordered a new filter and just bought some new spark plugs.
I need to buy the stock spark plug tool from honda to change the sparks.
Not sure what this issue is but a resolve would make my life easier.
Thanks all
post #3 of 15 (permalink) Old 06-10-2017, 05:40 PM
Check your battery.
jpr1968 is offline
post #4 of 15 (permalink) Old 06-10-2017, 06:02 PM
Check the basics first. I think the spark plugs are a good start. You can buy any spark plug wrench (just make sure you get the right size) from a hardware store and use an extension to get them out. Look at the color of the spark plugs as they can be a good indication of how it is running. A quick google search will be helpful for that.
I wouldn't be too concerned about the oil in the filter. That could happen if someone put too much oil in it. It should probably be replaced though if you are unsure how old it is.
Make sure all electrical connections are tight and clean any corrosion in the connections and look for loose or chafing wires. Just make sure you disconnect the battery before touching anything electrical.
How many miles are on it?
Best of luck!
winterloon is offline
post #5 of 15 (permalink) Old 06-10-2017, 06:37 PM Thread Starter
This was the solution for the battery dying! Thank you!!
post #6 of 15 (permalink) Old 06-10-2017, 06:40 PM Thread Starter
I tried to buy a socket for it but it stumped both the oreilly guy and myself. It just wouldn't grab the spark plug.
Know the exact size that would be a fit?
It turned back on after tightening the loose battery cable.
Would that really cause ALL of those symptoms?
I'll be changing out the plugs and air filter too.
What type of coolant should I use?
Silicate free? brand? type?
Thank you so much!!!
post #7 of 15 (permalink) Old 06-10-2017, 09:34 PM
GB6049's Avatar
Model: Shadow Spirit VT750 DC
Year: 2006
You need power to fire the coils and keep it running.
Checking and changing the fluids is a good thing to do with any new vehicle. Since the coolant change is not the easiest, you just get a hydrometer and check to see what condition it is in. Also drain your carbs for any trapped water, add some fuel treatment for any old gas or water in the tank and replace the fuel filter. Clean, lube and check chain tension along with sprocket wear.
Otherwise ride it.
GB6049 is offline
post #8 of 15 (permalink) Old 06-11-2017, 12:36 AM
As I stated earlier, check the battery. A weak battery will cause those symptoms. You need a thinwall deep 18mm socket for the sparkplugs.
jpr1968 is offline
post #9 of 15 (permalink) Old 06-11-2017, 12:40 AM
bd*
bd*'s Avatar
Model: Shadow Spirit 750
Year: 2001
Originally Posted by jpr1968 View Post
Check your battery.
Yes Start with checking your battery connections. My positive was lose last month and it caused all kinds of electrical issues.
The wife and I on My, 2001 Shadow Spirit
750.....
bd* is offline
post #10 of 15 (permalink) Old 06-11-2017, 01:43 AM
swifty2014's Avatar
Model: Vt750
Year: 1983
You said loose battery cable, that will cause a lot of problems.
If you can get it running now, put a meter on the battery. Look for about 12.5 volts sitting, engine off. Over 9.5 volts cranking. And about 13.5 to 14.5 volts when you rev it up to 3000 RPM. That will tell most of the info you need for the battery and charging system.
1983 750 Shadow
From the past=
1951 Cushman scooter
1962 Honda 305 Dream
1965 Honda 305 Dream
1971 Honda 175 scrambler
swifty2014 is offline
Ignition differences between an '06 VLX and '06 750 Spirit firehawk Technical Discussion 2 12-29-2014 04:20 PM
06 aero seat fit 06 spirit? ss243b Technical Discussion 1 03-06-2013 10:58 AM
Selling 06 Spirit 750 for New 06 Sabre NJSPIRIT General Bike Discussion 6 03-26-2008 04:29 PM
Walmart Oil Filter for 06 Honda Shadow Spirit 750 bclinton Technical Discussion 7 08-30-2007 04:35 PM
