Progressive fork springs, oil weight and tapered bearings - Honda Shadow Forums : Shadow Motorcycle Forum
post #1 of 12 (permalink) Old 08-18-2017, 02:54 PM Thread Starter
What oil weight are you running/is recommended with progressive fork springs? I have a 2000 Shadow VT1100C
Also, for changing head bearings to tapered ones, what tools did you use to get the old races out/new races in? I have done this before with just a hammer and punch but that is not always easy depending on the bike.
dell30rb is offline
post #2 of 12 (permalink) Old 08-18-2017, 05:36 PM
Model: VLX 600
Year: 2003
I use Mobil1 synthetic ATF for fork oil. Works fine in a VFR800, VLX and 2 ST1100s. Seals last almost indefinitely. I don't have any tools that are specifically for head bearings.
gonerydin is online now
post #3 of 12 (permalink) Old 08-18-2017, 05:56 PM
same here ATF is perfect for vt1100 ,,,transmission fluid had detergent in in as well and keeps little valves clean
gerryfraser is offline
post #4 of 12 (permalink) Old 08-18-2017, 07:42 PM
I used 12.5 wt oil. I will be changing back to a 10wt next to try and soften things a touch. I think 7wt trans fluid might be to light for me. I just need a touch softer for in town. On the road I am fine how it is now. I found cuttong the spacer to what they reccomen is better than using the factory spacer for me. I just did that. I really like the springs though.
1995 VT1100 Ace
not2sure is offline
post #5 of 12 (permalink) Old 08-19-2017, 08:56 AM
h13man's Avatar
I was very pleased with the stock oil. Honda SS8 shares the same viscosity rating as Belray 10w. FWIW I rode two up about 80% of my mileage. Going back to Progressives on the Valk this winter. Not pleased with the Racetech single rate springs for the overall ride.
71' CL 100 "Lil' Sista"
99' Valkyrie "Adele"
05' 1600 Vulcan "Ludabelle"
Ride Bell by "Yoman"
h13man is offline
post #6 of 12 (permalink) Old 08-19-2017, 10:26 AM
blue flames's Avatar
Model: 1100 spirit
Year: 2002
I used ATF in my 1100 w/stock springs I love the ride and feel. Haven't done bearings yet
RIDE SAFE!
Good guys ride black bikes
02 1100 Shadow Spirit "EVE"
blue flames is online now
post #7 of 12 (permalink) Old 08-19-2017, 10:38 AM
sidejam's Avatar
I went with heavier oil than recommended after swapping in Progressive springs. I still find the front end a bit soft.
sidejam is offline
post #8 of 12 (permalink) Old 08-19-2017, 11:45 AM
@sidejam , did you cut the spacer tubes down that they gave you? If so, using the stock tubes will stiffen it a touch more. At least it did on my bike.
1995 VT1100 Ace
not2sure is offline
post #9 of 12 (permalink) Old 08-19-2017, 03:42 PM
sidejam's Avatar
I can't recall exactly... but, I'm pretty sure we had to cut the tubes down. I remember my mechanic calling Progressive to make sure they were cut to the correct length.
Today, I dialled up the settings on the rear shocks. Front and rear seem to be working well together now. If I decide to hang on to the bike, I'll likely pull the Progressive springs out and replace them with RaceTech springs and Gold Valve Emulators.
sidejam is offline
post #10 of 12 (permalink) Old 08-20-2017, 09:28 AM
h13man's Avatar
For some odd reason I had go purchase more tube as they sent me too short in length pieces to get the 1/2" preload.
h13man is offline
Progressive fork springs oil level For '98 VT1100T NGreen Technical Discussion 7 11-23-2016 08:21 AM
Straight-Rate Springs vs. Progressive Rate Springs WildDoktor Technical Discussion 35 03-08-2015 09:46 PM
Progressive springs in forks and fork oil tool recommendation! SableAble Technical Discussion 0 05-05-2013 05:47 PM
Steering bearing grease for tapered bearings? downinit25i Technical Discussion 3 01-10-2010 12:46 AM
Progressive Springs fork oil level question pixelpusher Technical Discussion 5 04-06-2008 09:36 PM
