Handlebar replacement - Page 2 - Honda Shadow Forums : Shadow Motorcycle Forum
post #11 of 19 (permalink) Old 10-29-2017, 06:52 PM
You realize that if you go to 1" bars, none of the controls will fit on the bars.
jpr1968 is offline
post #12 of 19 (permalink) Old 10-29-2017, 07:38 PM
sidejam's Avatar
I was thinking the same thing.
However, Iíve noticed people that are fixing bikes from the 80ís, are usually unreasonably and illogically cheap. I canít understand the decision progress as to why he doesnít just buy new bars with the right diameter. Curious to see how this turns out...
sidejam is offline
post #13 of 19 (permalink) Old 10-29-2017, 07:58 PM
Model: 2007 Shadow 600
He likes thicker handlebars better. If memory serves, there was a discussion that mentioned that some 1-inch handlebars taper down to 7/8-inch at the grips, probably as a marketing strategy.
2007 Honda Shadow 600
RONW is offline
post #14 of 19 (permalink) Old 10-29-2017, 08:18 PM
Year: 2000
The suggestion to take it to a machine shop and have the riser bored to 1" is intriguing. I have a sneaking suspicion that the price to do that will far outweigh any benefits to be gained. Special fixtures to hold the part would have to be built, then more problems would surface as to how to hold the boring bar steady. Just my opinion, of course.
Chuck_Michigan is offline
post #15 of 19 (permalink) Old 10-29-2017, 08:53 PM
sidejam's Avatar
Hopefully, if this is done, there is a spacer added between the top clamp and the triple tree during the boring process. Otherwise, it will be exactly 1" and won't clamp at all.
There must be an interesting back story to the project?
Couldn't just pick from one of these?
J&P Cycles.com 7/8 Inch Diameter
sidejam is offline
post #16 of 19 (permalink) Old 10-29-2017, 09:47 PM
Sundown's Avatar
I would encourage you to think some more about it. Personally I think it might be a mistake.
How many things like the clutch lever assembly and front brake lever / throttle assembly have pin holes , stuff like that.
Finding particular accessories to fit the 7/8" bars might be a hassle , but I do know that many times I've felt the same way about the 1" bars.
Price the machine shop work on the clamps , that might make the decision for you.
But @PhantomRider64 is right it may be your only way.
Make sure whoever you have do the machining knows what he is doing........might be a real bear to have to find a new clamp assembly to replace it.
"At all times you are only where you really want to be," unknown old man in a desert lightning storm.
Sundown is offline
post #17 of 19 (permalink) Old 10-29-2017, 10:17 PM
I gather it's a me and my bike kinda thing. Anyways, the bore itself has to be 1" on the money to match the diameter of the 1" bars. It just that the halves aren't cut off at the equator, so they're not complete semi-circles. This preserves the clamping function via the gap (missing latitudes) between the two items.
RONW is offline
post #18 of 19 (permalink) Old 10-30-2017, 12:39 AM
sidejam's Avatar
Lol. Ya... that's what I meant. I just didn't put it quite so eloquently!
Hopefully, the machine shop will do it properly and the bars will clamp securely.
sidejam is offline
post #19 of 19 (permalink) Old 10-30-2017, 02:48 AM
Sundown's Avatar
Very well said. Not that it can't be done , but whoever is doing it gotta get it.
Sundown is offline
Replacement Handlebar Ideas For 98 Aero VT1100C3 Vmaxman Member Introductions 3 01-06-2013 09:47 PM
2006 Honda Shadow VT750DC Handlebar Replacement Rob Hutton Member Introductions 1 05-29-2012 09:17 PM
Handlebar Replacement jj.smith Technical Discussion 7 03-03-2012 07:41 PM
Sabre Handlebar Replacement Suggestions? mbopp Technical Discussion 10 05-26-2011 09:50 PM
Handlebar Replacement PHiggins01 General Bike Discussion 3 08-23-2009 09:09 PM
