1984 500c - stalls with throttle - Page 2 - Honda Shadow Forums : Shadow Motorcycle Forum
post #11 of 18 (permalink) Old 07-10-2018, 10:09 AM
swifty2014's Avatar
Model: Vt750
Year: 1983
If the carbs are coming off again you can do a bench sync by sliding a .002 " feeler gauge under each throttle plate to get then very close to an equal setting.
I always think of these V twins with 2 carbs as 2 separate engines connected together. You want all the parts contributing equally for smoothness and power.
1983 750 Shadow
From the past=
1951 Cushman scooter
1962 Honda 305 Dream
1965 Honda 305 Dream
1971 Honda 175 scrambler
swifty2014 is offline
post #12 of 18 (permalink) Old 07-10-2018, 10:41 AM
tc862011's Avatar
Originally Posted by swifty2014 View Post
@ tc862011, I think you are confusing adjusting or balancing the idle mixture screws with syncing the throttle butterflys.
When you make both throttle plates move at the same time, both carbs and cylinders will be working the same for balanced power. That will work all the way up to wide open throttle.
Must of been bad info I was told, my bad
1986 honda shadow vt700c - roxy
tc862011 is offline
post #13 of 18 (permalink) Old 07-10-2018, 10:43 AM
swifty2014's Avatar
Model: Vt750
Year: 1983
You are right on the idle screws, they do only effect about up to 1/4 throttle.They are called the low speed circuit.
1983 750 Shadow
From the past=
post #14 of 18 (permalink) Old 07-10-2018, 10:46 AM
tc862011's Avatar
I agree with that info, was told that syncing the carbs is really just for a more even idle and doesnt help past 1/4 throttle, never really did my own research about it
tc862011 is offline
post #15 of 18 (permalink) Old 07-10-2018, 01:30 PM
Check to see if you have a kinked fuel line. That will greatly restrict or prevent any fuel from reaching the carb.
Jgirote9 is offline
post #16 of 18 (permalink) Old 07-12-2018, 09:43 PM
buschchris1's Avatar
Make sure air box is in place and sealing good. OEM box requires suction and too much fuel will drown it and stahl. Zero out the air/fuel screws and then. Go 2 turns out and test and then in quarter to half turn increments and see if it improves.
Also, leave the choke in. Once i restored my 02 VT750dc i found i never need choke... Ever. If you put an after market air intake, this could be the problem. Use clean plugs and then idle it for say 30min. Then check a plug. If its oily, too much fuel. If its a burnt white, too much air. Hope this helps.
buschchris1 is offline
post #17 of 18 (permalink) Old 09-15-2018, 11:54 PM Thread Starter
Hi all, thanks so much for the help.
I ended up going to a trusted mechanic for help. After listening to all the attempts I made with the carbs, he promptly told me to "not mess with the carbs". He then informed me that the problem was dirty carbs. Hard to imagine after taking them off twice, but I'm not complaining. The bike runs a dream now. Appreciate everybody who replied.
84vickie is offline
post #18 of 18 (permalink) Old 09-16-2018, 09:14 PM
swifty2014's Avatar
Model: Vt750
Year: 1983
Good to hear of a fix. Ride safe.
1983 750 Shadow
From the past=
1984 Honda Shadow 750 stalls with throttle RaithM Technical Discussion 17 07-12-2015 08:57 AM
1984 shadow vt 500c death06969 Member Introductions 0 05-29-2013 07:04 PM
1984 Honda Vt 500c Ignition switch JSIN Technical Discussion 10 08-22-2011 08:49 PM
1984 VT 500C Shadow JSIN Member Introductions 0 08-13-2011 07:28 PM
